Designed with your specific system in mind, Kingston system-specific memory makes it easy to select exactly what you need, based on your OEM system brand and model. Kingston engineers use only the highest quality components on the market to ensure maximum performance and legendary Kingston reliability. All Kingston system-specific memory is guaranteed to be compatible with the system for which it was designed – which takes the hassle out of selecting memory for your notebook or desktop.
Testing
Kingston is one of the few manufacturers that qualifies all components and tests modules at all stages of production. -
Lifetime Warranty
All Kingston memory is backed by a lifetime warranty through Kingston. -
Free Technical Support
Kingston experts are standing by to share their knowledge and help you in the unlikely event that you have any problems with Kingston memory.
- Kingston - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty
- Designed For
- Dell Inspiron 3521; Latitude 3330; XPS 18
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Unbuffered
- Voltage
- 1.35 V
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- Designed For
- Dell Inspiron 3521 , Dell Latitude 3330 , Dell XPS 18
