HyperX HX426C15SBK2/32 is a kit of two 2G x 64-bit (16GB) DDR4-2666 CL15 SDRAM (Synchronous DRAM) 2Rx8, memory modules, based on sixteen 1G x 8-bit FBGA components per module. Total kit capacity is 32GB. Each module supports Intel® XMP (Extreme Memory Profiles). Each module has been tested to run at DDR4-2666 at a low latency timing of 15-15-15 at 1.2V. The SPDs are programmed to JEDEC standard latency DDR4-2133 timing of 15-15-15 at 1.2V. Each 288-pin DIMM uses gold contact fingers.
- HyperX Savage - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 2 x 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL15 (15-15-15)
- Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heatspreader, sixteen banks, asymmetrical heatspreader, unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 32 GB: 2 x 16 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.36
- Speed
- Latency Timings
- CL15 (15-15-15)
- Non-ECC
- Module Configuration
- 2048 x 64
- Chips Organization
- 1024 x 8
- Voltage
- 1.2 V
- Lead Plating
- Gold
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.2 V - CL15 - 15-15-15
- Colour Category
- Black
