Kingston 16GB DDR3L DIMM 240-pin 1333 MHz / PC3-10600 - registered - ECC
Quicklinx: 8F2MWS00 Mfr#: KTH-PL313LV/16G
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
16GB Module - DDR3L 1333MHz
Part Number: KTH-PL313LV/16G
Kingston - DDR3L - module - 16 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
Memory module
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Low Voltage, registered
HP 627808-B21, HP 627812-B21
Limited lifetime warranty (Russia - 10 years)
HPE ProLiant BL280c G6, BL2x220c G7, BL460c G7, BL465c G7, BL490c G7, BL620C G7, BL680c G7, BL685c G7, DL160 G6, DL165 G7, DL180 G6, DL320 G6, DL360 G7, DL370 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G7, DL980 G7, ML350 G6, ML370 G6, SL160s G6, SL160z G6, SL170s G6, SL335s G7, SL390s G7
16 GB
Upgrade Type
System specific
DRAM memory module
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
HPE ProLiant BL2x220c G7, BL460c G7, BL465c G7, BL490c G7, BL620C G7, BL680c G7, BL685c G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL360 G7 Central Management Server, DL370 G6 High Performance, DL370 G6 Special Server, DL380 G7 Special Server, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, SL160s G6, SL160s G6 Base, SL160s G6 Entry, SL160s G6 Performance, SL170s G6 1U Left Half Width tray, SL170s G6 1U Right Half Width tray, SL170s G6 Base 1U Left Half Width tray, SL170s G6 Base 1U Right Half Width tray, SL170s G6 Entry 1U Left Half Width tray, SL170s G6 Entry 1U Right Half Width tray, SL170s G6 Performance 1U Left Half Width tray, SL170s G6 Performance 1U Right Half Width tray, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server, SL390s G7, SL390s G7 1U Left Half Width tray, SL390s G7 1U Left Tray Node Server, SL390s G7 1U Right Half Width tray, SL390s G7 1U Right Tray Node Server, SL390s G7 2U Left Half Tray Node Server, SL390s G7 2U Right Half Width tray, SL390s G7 4U Left Half Width tray, SL390s G7 4U Left Tray Node Server, SL390s G7 4U Right Half Width tray, SL390s G7 4U Right Tray Node Server, SL390s G7 Base 1U left Half Width tray, SL390s G7 Base 1U Right Half Width tray, SL390s G7 Base 2U Left Half Width tray, SL390s G7 Base 2U Right Half Width tray, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Base 4U Right Half Width tray, SL390s G7 Entry 1U Left Half Width tray, SL390s G7 Entry 1U Right Half Width tray, SL390s G7 Entry 2U Left Half Width tray, SL390s G7 Entry 2U Right Half Width tray, SL390s G7 Performance 1U left Half Width tray, SL390s G7 Performance 1U Right Half Width tray, SL390s G7 Performance 2U Left Half Width tray, SL390s G7 Performance 2U Right Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray
