The GN 2000 Series contact center headsets feature superb call clarity. Tested to withstand rough handling and comfortable enough to wear all day. Best of all, the GN 2000 Series offers far more than you would expect from an affordable headset.
Built to last, the GN 2000 series is GN toughest contact center headset yet. The GN 2000 Series is a straightforward, easy-to-use headset. Experience crystal clear communications as the noise-canceling microphone reduces unwanted background noise - even in noisy offices.
Large ear cushions provide exceptional comfort thanks to fully gimballed mountings. That means GN earpieces automatically adjust to the shape and angle of the ear. And less manual adjustment means you can concentrate on the call and not on the headset.
What's more, this remarkable headset also features GN PeakStop technology, which cuts off sudden loud noises above 118 dB SPL.
- Robust design for day-after-day durability
- Large ear-cushions for extra comfort
- Noise-cancelling microphone
- Includes GN1200 Smart Cord, foam and leatherette ear pads free in the box
Jabra GN1200 Smart Cord
The Jabra GN1200 Smart Cord is the solution to a common problem of not being able to connect headset and telephone. Even though most things have been standardized, the cord connecting the phone with the handset or headset is anything but standard as each telephone manufacturer has its own wiring code. Now, with the universal "smart" cord, GN 1200, the cord will work with virtually any phone providing greater convenience.
- Jabra GN 2000 IP - headset - with GN 1200
- Product Type
- Headset - wired
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Bundled with
- GN 1200
- Product Type
- Headset - wired
- Bundled with
- GN 1200
Audio Output
- On-ear monaural
- Wired
- Sound Output Mode
- Mono
Microphone
- Boom
- Mono
