When you have a busy lifestyle, car journeys can give you some well-needed breathing space to catch up and make arrangements with friends and family on the phone. The problem is, though, it's illegal! Jabra Drive in-car speakerphone solves this, and other problems, with an excellent hands-free solution, so you can make the best use of this time - and have in-car phone conversations without compromising safety.
Jabra Drive is brilliantly simple. No setup is required, and it's so easy to operate, you probably won't even have to look in the manual to find out how to use it. Voice guidance talks you through as you pair it up with your mobile for the first time. After that, you just clip it onto your sun visor and it will connect automatically whenever you get into the car.
You can then talk freely on your mobile, with your eyes on the road and your hands on the wheel. With the Jabra Drive, you don't even need to bother reaching for your phone when it rings. It's always at your fingertips, whenever you're on the road - just press the big friendly button on the in-car speakerphone to answer and enjoy crystal clear hands-free conversation!
No hassle, no fuss
Extremely easy to use. Voice-guided instructions tell you how to connect to your phone. You also receive spoken updates when you're connected or low on battery. Once Jabra Drive is paired with your phone, it will connect automatically when it's in range. When a call comes in, use the dedicated control buttons to answer it directly from Jabra Drive. -
Picks up your voice, And nothing else
Even though you're on the road, you don't want to sound like you are. Noise cancellation technology dampens the road noise and gives you clear, crisp sound for your calls. -
More than just calls
Stream music from your phone and get GPS directions played through Jabra Drive. Connect to two active Bluetooth devices at the same time. Use them interchangeably to play music or take calls.
- Jabra Drive - Bluetooth hands-free car kit
- Product Type
- Integrated Components
- DSP
- Wireless Interface
- Bluetooth
- Battery
- Rechargeable
- Package Content
- Car battery charger, USB cable, Bluetooth hands-free speakerphone
- 5.6 cm x 10.4 cm x 1.8 cm
- 100 g
- 1-year warranty
- Product Type
- DSP
- Bluetooth 3.0
- Max Operating Distance
- 10 m
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP)
- Package Content
- 5.6 cm
- 10.4 cm
- 1.8 cm
- 100 g
- Rechargeable Battery
- Rechargeable
- Volume control
- 1 year
