The Jabra DIAL™ 520 USB delivers professional performance and great value. It's the cost-effective USB handset solution optimized for Unified Communications solution with an easily recognizable user interface, it is the ideal product for every type of Unified Communications user. Through its seamless integration with the audio features in leading Unified Communications applications it is possible to truly reap the benefits of IP telephony.
Through its resemblance to well-known phones the Jabra DIAL™ 520 USB is a sure way to migrate users onto IP telephony. Its plug & play capabilities ensure that even the very first call is easy to make - simply connect the handset and use it like any other dialpad based phone. Due to the portability of Jabra DIAL™ 520 USB, the product is equally applicable for office-based and home-based professionals. And its small size and slim design make it convenient to bring along.
- True wideband audio performance for professional sound
- Intuitive, plug-and-play usability
- Dedicated answer/end and mute buttons for seamless integration with UC applications
- LCD display showing numbers dialed
- Small dialpad and slim design for easy portability
- Powered by USB so there's no need for batteries
- This USB phone works only as an audio device only when used with Skype, Googletalk etc, the dial pad and call control or caller ID will not work.
Easy and intuitive handset for Unified Communications
Jabra's Dial 520 delivers the features and functionality of a standard handset so users can quickly take advantage of the collaboration capabilities that Unified Communications and softphone platforms provide with the convenience they desire.
- Jabra DIAL 520 OC - USB VoIP handset / speakerphone
- Product Type
- USB VoIP handset / speakerphone - wired
- Connectivity Technology
- Wired
- Microphone
- Built-in
- Controls
- Mute, answer/end
- Product Type
Audio Output
- Wired
Remote Control
- Controls
- Mute, answer/end
- Connector Type
- USB (4 PIN USB Type A)
- Plug and Play
