A revolution in ultra-compact device design, the Intel NUC NUC5i5RYK packs more features into 4 inches square. The NUC5i5RYK is equipped with the 5th generation Intel Core i5-5250U processor with Intel Turbo Boost Technology 2.0 which gives you extra GHz on demand to let you maximize performance on processor-intensive tasks like media editing. A replaceable lid gives you plenty of options to create the NUC you want - with amazing style and features. It also features Intel HD Graphics 6000 with 4K display capabilities to provide visually stunning graphics. A high-speed USB 3.0 charging port lets you easily charge your tablet or smartphone quickly. Complete with WiFi 802.11ac wireless, Bluetooth, and 7.1 surround sound, the Intel NUC NUC5i5RYK is ideal for home theater PCs, media server PCs, and home hubs. For peace of mind, you'll get embedded security that helps keep threats out and user identities and credentials safe. With this kind of power, size, and versatility, you'll rethink what's possible.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC5i5RYK - mini PC - Core i5 5250U 1.6 GHz - 0 GB - no HDD
- PC barebone - mini PC - voltage monitoring, temperature sensor, Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
- Processor
- 1 x Intel Core i5 (5th Gen) 5250U / 1.6 GHz (, up to 2.7 GHz, (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 6000
- Audio Output
- 7.1 channel surround - integrated
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- No operating system
- Silver with black top and diamond cut around the top
- 11.5 cm x 11.1 cm x 3.45 cm
- Limited warranty - replacement - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5250U
- Clock Speed
- 1.6 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- ACPI support, Intel Wireless Display (WiDi)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Card
- 4 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x SATA-600 (2 internal)
- Included Accessories
- VESA mounting kit
- Voltage monitoring, temperature sensor, Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ACPI 3.0b, VCCI V-3, Directive 2002/96/EC, VCCI V-4, KN22, KN24, China RoHS, Directive 2011/65/UE, CAN/CSA-C22.2 No. 60950-1
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.5 cm
- 11.1 cm
- 3.45 cm
- 0 °C
- 50 °C
