dabs.com exclusive: Ready to go Intel NUC bundle, pre-built with Kingston mSATA 60GB SSD and 4GB SODIMM 1600MHz
dabs.com have teamed up with PC Specialist to bring you the Intel NUC Dual Core Celeron 847 QS77 with USB 2.0 and 2 x HDMI pre-assembled with everything you need! Inside this NUC you'll find a Kingston mSATA 60GB SSD and Kingston 4GB SODIMM 1600MHz memory. Simply add an Operating System and you're ready to enjoy the Next Level of Computing!
The Next Unit of Computing (NUC) Kit DCCP847DYE delivers new levels of performance and responsiveness in a pocket-sized solution. With an Intel Celeron processor, the NUC is an affordable, customizable computing system that fits in the palm of your hand and offers a world of flexibility.
This fully scalable, next generation computing device provides a flexible, customizable engine. Create a PC home system to experience your movies and photos or drive digital signage such as menus, news and weather. The NUC challenges you to rethink what's possible. Because the only thing more amazing than Intel technology is what you'll do with it.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit DCCP847DYE - UCFF - Celeron 847 1.1 GHz - 0 GB - no HDD
- PC barebone - ultra compact form factor - voltage monitoring, temperature sensor, automatic fan speed control
- Processor
- 1 x Intel Celeron 847 / 1.1 GHz (Dual-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics
- Audio Output
- 7.1 channel surround - integrated
- Networking
- 1GbE
- OS Provided
- No operating system
- 11.66 cm x 11.2 cm x 3.9 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Ultra compact form factor
Processor / Chipset
- CPU
- Intel Celeron 847
- Clock Speed
- 1.1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
- Chipset Type
- Mobile Intel QS77 Express
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Data Link Protocol
- ACPI support
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x Mini PCIe - full-length , 1 (total) / 1 (free) x Mini PCIe - half-length
- 3 x USB 2.0 (1 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x HDMI
- Included Accessories
- VESA mounting kit
- Voltage monitoring, temperature sensor, automatic fan speed control
- Theft/Intrusion Protection
- CISPR 24, EN 61000-3-2, EN55022, ICES-003, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC CFR47 Part 15 B, GOST-R, CSA C22.2 No. 60950-1, VCCI V-3, EMC Class B, NOM-019-SCFI-1998
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 11.66 cm
- 11.2 cm
- 3.9 cm
- 0 °C
- 55 °C
