The InFocus IN100 Series are not only some of the lowest cost projectors, but also have one of the longest-lasting lamps - for incredibly low total cost of ownership.
These value-packed projectors are easy to buy and built to perform with high brightness, high contrast ratio and BrilliantColor technology. Plus, their slim, compact design and light weight make them as easy to move around as they are to install.
Lowest total cost of ownership
The IN100 Series are not only the lowest priced office / classroom projectors, but their lamp lasts 50% longer than the previous generation. There aren't even any filters to replace. It's an unbeatable value. -
High brightness and high contrast
The image quality of these projectors will not disappoint. These projectors will give you bright, clear images with the lights on and the high contrast ratio adds sharpness with darker blacks and whiter whites. Preset modes give you the best image quality on a beige wall, whiteboard, blackboard or other surface. -
Resolution options
Choose from native resolution of SVGA for the best price, XGA for better image detail and clarity, or widescreen WXGA resolution for projecting high definition video and wide laptop screens without scaling. -
Compact, slim and light
The IN100 Series is small and lightweight for easy portability from one room or building to the next.
