Through all stages: concept, design and development - the ProLite GB2773HS was meant to be a real game changer giving true hardcore gamers the competitive edge they need to make split second decisions. Smooth and judder free graphics during fast paced games are guaranteed by the use of a high quality 144 Hz panel with a blistering 1ms response time. Ergonomic, height adjustable stand allows you to easily adjust the screen position to your preferences. It offers a truly amazing gaming experience.
144 Hz refresh rate
The use of a high quality 144 Hz panel guarantees a flawless gaming experience - less fracturing, smoother graphics motion during fast paced games and judder free animations. For 144 fps game-play it is required to have a graphic card that supports dual link 120 Hz DVI. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
HDMI (High-Definition Multimedia Interface)
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
ACR (Advanced Contrast Ratio)
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HAS
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
- iiyama ProLite GB2773HS-1 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 53 kWh
- Power Consumption (On mode)
- 36.5 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.7 cm x 23 cm x 41.55 cm
- 7.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, GOST-R, TUV Bauart
- Display Type
- Energy Class
- Class B
- 53 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 144 Hz
- Horizontal Refresh Rate
- 30 - 159 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock
- OSD Languages
- English, German, French, Italian, Finnish, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
- Black
- 7.4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2.5 Watt
- VGA , DVI-D , HDMI , Headphones
Mechanical
- Tilt Angle
- 17
- Swivel Angle
- 90
- Height Adjustment
- 107 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 36.5 W
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
- ENERGY STAR Certified
