iiyama ProLite B2480HS-B1 24" 1920x1080 VGA DVI HDMI Height Adjustable LED Monitor
Quicklinx: 87ZLWS00 Mfr#: B2480HS-B2
The ProLite B2480HS is a high specification 24'' Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 2msec response time and >5 000 000 : 1 Advanced Contrast Ratio make the B2480HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star and TCO Certified.
87ZL C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
