The XB2779QS can display almost 77% more information on the screen than a Full HD display. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent color reproduction, wide viewing angles and a fast response time. The XB2779QS is perfect for demanding users who settle only for the best specifications and modern design.
WQHD
With true WQHD 2560 x 1440p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen, i.e. over 76% more in comparison to a 1920 x 1080 monitor. -
AH-IPS
The AH-IPS panel technology guarantees consistent color reproduction with wide viewing angles and high contrast. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable for both business and home use. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
HAS
A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
- iiyama ProLite XB2779QS-1 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class D
- Energy Consumption per Year
- 98 kWh
- Power Consumption (On mode)
- 67.3 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 440 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver black
- 65 cm x 23 cm x 43.55 cm
- 8.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- VESA DPMS, PSE Mark, GOST-R, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class D
- 98 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 440 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- Silver black
- 65 cm x 23 cm x 43.55 cm - with stand
- 8.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Audio line-in , Headphones , DisplayPort
Mechanical
- Tilt Angle
- 17
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable
- Power Supply
- Internal
- Input Voltage
- 67.3 W
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
- Dimensions & Weight Details
- With stand - width: 65 cm - depth: 23 cm - height: 43.55 cm - weight: 8.2 kg
Sustainability Information
- ENERGY STAR Certified
