- HPE Aruba - power supply - 1100 Watt
- Power supply - plug-in module
- 2.74 kg
- Power Capacity
- 1100 Watt
- 18.92 cm x 15.87 cm x 12.95 cm
- Designed For
- HPE Aruba 5406R 8-port 1/2.5/5/10GBASE-T PoE+ / 8-port SFP+ (No PSU) v3 zl2, 5406R-44G-PoE+/2SFP+ v2 zl2, 5406R-44G-PoE+/4SFP v2 zl2, 5412R 92GT PoE+ / 4SFP+ (No PSU) v3 zl2, 5412R-92G-PoE+/2SFP+ (No PSU) v2 zl2, 5412R-92G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5412R-92G-PoE+/4SFP v2 zl2 (1100 Watt)
- Power Capacity
- 1100 Watt
- 18.92 cm
- 15.87 cm
- 12.95 cm
- 2.74 kg
- Designed For
- HPE Aruba 5406R 8-port 1/2.5/5/10GBASE-T PoE+ / 8-port SFP+ (No PSU) v3 zl2 (1100 Watt), 5406R-44G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5406R-44G-PoE+/4SFP v2 zl2 (1100 Watt), 5412R 92GT PoE+ / 4SFP+ (No PSU) v3 zl2 (1100 Watt), 5412R-92G-PoE+/2SFP+ (No PSU) v2 zl2 (1100 Watt), 5412R-92G-PoE+/2SFP+ v2 zl2 (1100 Watt), 5412R-92G-PoE+/4SFP v2 zl2 (1100 Watt)
