Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Designed and Engineered to Provide High Capacity and Reliable Secure Storage
HPE Server Midline Hard Drives are ideal for bulk data storage, cloud and web infrastructure environments.Broad portfolio of optimized solutions provide up to 10 TB of storage, and growing in a single device.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) in a wide variety of capacity points.Prevent unauthorized access to your data with HPE Digitally Signed Firmware. It provides the security and assurance that drive firmware comes from a trusted source and protects against malicious attacks. -
Support Entry/SMB servers with value priced drives
HPE Server Midline Hard Drives have lower start-up costs without sacrificing reliability at the lowest $/GB.Non-mission critical hard drives at the lowest $/GB.6 Gb/sec data transfer rate to support existing servers.
- HPE Midline - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - hot-swap
- Capacity
- 3 TB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- 1-year warranty
- Bundled with
- HPE SmartDrive carrier
- Designed For
- ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL80 Gen9, MicroServer Gen8, ML110 Gen9, ML110e Gen8, ML30 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, SL4545 G7, WS460c Gen8; StoreEasy 1550, 1650
- Capacity
- 3 TB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- Designed For
- HPE ProLiant BL460c Gen8 (3.5"), BL660c Gen8 Performance (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL360 Gen9 CMS (3.5"), DL360e Gen8 Special Server (3.5"), DL360p Gen8 (3.5"), DL360p Gen8 CMS (3.5"), DL360p Gen8 Performance (3.5"), DL380 Gen9 (3.5"), DL380 Gen9 Base (3.5"), DL380 Gen9 Entry (3.5"), DL380 Gen9 Performance (3.5"), DL380p Gen8 Performance (3.5"), DL385p Gen8 Entry (3.5"), DL385p Gen8 Storage Centric (3.5"), DL560 Gen8 Entry (3.5"), DL560 Gen8 Performance (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), MicroServer Gen8 (3.5"), MicroServer Gen8 Base (3.5"), MicroServer Gen8 Base Starter Kit (3.5"), MicroServer Gen8 Entry (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML110e Gen8 (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"), ML310e Gen8 (3.5"), ML310e Gen8 Base (3.5"), ML310e Gen8 Entry (3.5"), ML310e Gen8 Performance (3.5"), ML310e Gen8 v2 Base (3.5"), ML350 Gen9 (3.5"), ML350 Gen9 Base (3.5"), ML350 Gen9 Entry (3.5"), ML350 Gen9 Performance (3.5"), ML350e Gen8 v2 (3.5"), ML350e Gen8 v2 Base (3.5"), ML350p Gen8 (3.5"), ML350p Gen8 Special Server (3.5"), SL210t Gen8 (3.5"), SL210t Gen8 1U Node (3.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (3.5"), SL270s Gen8 1U Left Half Width Tray (3.5"), SL270s Gen8 1U Right Half Width Tray (3.5"), SL270s Gen8 Base 4U Left Half Width Tray (3.5"), SL270s Gen8 Base 4U Right Half Width Tray (3.5"), SL270s Gen8 SE 4U Left Tray (3.5"), SL270s Gen8 SE 4U Right Tray (3.5"), SL4540 Gen8 (3.5"), SL4540 Gen8 Tray 1x Node Server (3.5"), SL4540 Gen8 Tray 2x Node Server (3.5"), SL4540 Gen8 Tray 3x Node Server (3.5"), SL4545 G7 (3.5") , HPE StoreEasy 1550, 1650
