HPE HP 1910-24 Switch 24 Ports Managed Rack-Mountable
Quicklinx: BNS8WS00 Mfr#: JG538A
The HPE 1910 Switch Series, part of the HPE OfficeConnect portfolio, delivers Fast Ethernet connectivity for cost-conscious smaller organizations. The switches are ideal for environments that require granular control and where smart-managed flexibility is a must for easy network configuration and management. The 1910 Switch Series provides advanced, smart-managed, fixed-configuration switches in an easy-to-administer solution. Customizable features include basic layer 2 features like VLANs and link aggregation and advanced features such as Layer 3 static routing and ACLs.
  • Simplifies Network Deployment and Management for Small Organizations
    The HPE 1910 Switch Series features easy-to-use, out-of-the box, plug-and-play deployment.Series offers a complete portfolio of choices for increased flexibility. It consists of five rack-mountable models with internal power supplies including three non-Power over Ethernet (PoE) models: 8-, 24- and 48-port and two PoE+ models: 8- and 24-port. All models come with two combo uplink ports.These smart-managed switches use an intuitive Web management interface to simplify deployment and management while offering you greater granularity of control of key features.
  • Keeps Your Business up and Running and Protected
    Enhanced security features such as Access Control List, IEEE 802.1x and VLANs guard your network from unwanted or unauthorized access.Management security restricts access to critical configuration commands, offers multiple privilege levels with password protection, and supports secure http (https).The 1910 Switch Series is covered by the Hewlett Packard Enterprise Limited Lifetime Warranty.
  • Delivers Improved Performance, While Lowering Total Cost of Ownership (TCO)
    The HPE 1910 Switch Series delivers advanced functionality in smart-managed switches, including Layer 3 static routes, SFP ports, IPv6 support, rate limiting, link aggregation, and IGMP.The switch series includes PoE+ options to power IP devices without the cost of additional power outlets.Advanced silicon technology delivers greater energy-efficiency and the Limited Lifetime Warranty significantly reduce TCO.
HPE 1910-24 Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x combo Gigabit SFP
Routing table entries: 32
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 2, SNMP, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, Layer 3 switching, Layer 2 switching, DHCP support, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, IPv6 support, half duplex mode, full duplex mode, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Cable Diagnostics Function, STP Root Guard, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), dual firmware images, NTP time synchronisation, link aggregation trunking, packet storm protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS
8 x 100Base-TX RJ-45 , 2 x 1000Base-X SFP , 2 x 1000Base-T RJ-45
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, EN 61000-3-2, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, FCC Part 15, ICES-003 Class A, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03
Limited warranty - lifetime
BNS8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
