900GB hot-plug dual-port SAS hard drive - 10,000 RPM, 6Gb/sec transfer rate, 2.5-inch small form factor (SFF), Enterprise, SmartDrive Carrier (SC)
- HPE - hard drive - 900 GB - SAS 6Gb/s
- Hard drive - internal
- Capacity
- 900 GB
- Form Factor
- 2.5"
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 10000 rpm
- Designed For
- ProLiant BL460c Gen8 (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 Base (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Entry (2.5"), DL360p Gen8 High Performance (2.5"), DL380p Gen8 (2.5"), DL380p Gen8 Base (2.5"), DL380p Gen8 Entry (2.5"), DL380p Gen8 High Performance (2.5"), DL380p Gen8 Special (2.5"), DL388p Gen8 Base (2.5")
- Capacity
- 900 GB
- Form Factor
- 2.5"
- Interface
- SAS 6Gb/s
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 10000 rpm
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 2.5"
- Designed For
- HPE ProLiant BL460c Gen8 (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 Base (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Entry (2.5"), DL360p Gen8 High Performance (2.5"), DL380p Gen8 (2.5"), DL380p Gen8 Base (2.5"), DL380p Gen8 Entry (2.5"), DL380p Gen8 High Performance (2.5"), DL380p Gen8 Special (2.5"), DL388p Gen8 Base (2.5")
