HP Z24i 24" 1920x1200 VGA DVI-D DisplayPort IPS Monitor
Quicklinx: 98QHWS00 Mfr#: D7P53AT#ABU
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z24i 61 cm (24') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
  • Say hello to your new power-smart IPS Gen 2 team player
    Lower your power consumption and get 99% coverage of sRGB color spaces from IPS Gen 2 panels. Speed team reviews and collaborative decision-making with extra-wide viewing angles that give everyone the same great view.See all the stunning details on a 61 cm (24') diagonal display with narrow bezels and 1920 x 1200 resolution, which delivers 120 extra lines of data and 2.3M pixels.Experience crisp, clear presentation from 300 cd/m2 brightness, 1000:1 contrast ratio, 5M:1 dynamic contrast ratio, and 8 ms response time.Enhance the dark regions of your onscreen images and see the smallest details even better with integrated Black Stretch technology.
  • Designed-in comfort
    Find your most comfortable position with an HP-exclusive 4-way adjustable stand and an integrated HP QR2 Quick Release than enables VESA mounting.
  • Easy-access connectivity within arm's reach
    Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, and an integrated USB hub.
  • Keep it together
    Get organized with the integrated cable management clip. Create a clean, compact all-in-one with the optional HP Thin Client Mount Kit. The HP QR2 Quick Release is integrated into the display to enable quick set up, and it's VESA mountable.
  • Control your environmental impact
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that goes beyond IPS Gen 2 technology with ENERGY STAR and EPEAT Gold qualifications.The HP Z24i 61 cm (24') IPS Display also includes mercury-free display backlights, a low halogen design, and arsenic-free display glass.
  • Meet your monitor's new best friend
    Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Help deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval.
  • Breathe easy
    Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select optional HP Care Pack Services to extend your protection up to 5 years.
HP Z24i - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
55.94 cm x 23.79 cm x 52.5 cm
6.96 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA
3-year warranty
Display Type
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare
6.96 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
120 mm
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
36 Watt
Included Software
Dimensions & Weight Details
Width: 55.94 cm - depth: 6.45 cm - height: 36.5 cm - weight: 4.73 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
