The HP W2072a 50,8 cm (20") LED Backlit LCD Monitor combines flawless form and high-quality viewing at an affordable price – all with the environment in mind. Its thin design, with integrated speakers and simple "plug and play" connectivity, complements any HP desktop without sacrificing space.
Sophisticated meets affordability
Experience remarkable brightness, contrast and clarity in this slim and sleek LED monitor with a price tag that's in your budget. -
The power of LED
Mercury-free backlighting from LED monitors not only consumer less power, but also provide quick on/off switching time in comparison to the CCFL panel monitors. -
Quality you can count on
Enjoy 50,8 cm (20") of brilliant visual performance with a 1600x900 resolution, 3,000,000:1 dynamic contrast ratio and a 5ms on/off response time processor. Integrated speakers and VGA/DVI-D inputs provide a powerful, simple space-saving solution. -
Eco-Highlights
The HP W2072a 50,8 cm (20") LED Backlit LCD Monitor is designed with the environment in mind. • Arsenic free display glass • Mercury free LED backlighting • China Energy Label. -
HP Support, service and dependability
Includes a standard, limited warranty for parts and labor. Availability varies by region. Certain restrictions and exclusions apply. For details, contact HP Customer Support.
- HP W2072a - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Speaker
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.277 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 3000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.7 cm x 17 cm x 35.6 cm
- 3.5 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, TUV GS, VCCI, C-Tick, BSMI, GOST, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, E-Standby, KC, CECP, CEL, EPA
- 1-year warranty
- Display Type
- Diagonal Size
- 20"
- Built-in Devices
- Speaker
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.277 mm
- Pixel Per Inch
- 91.8
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K
- Controls & Adjustments
- Brightness, contrast, H/V position, clock
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 47.7 cm x 17 cm x 35.6 cm - with stand
- 3.5 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+19
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x power cable - 1.9 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 47.7 cm - depth: 4.78 cm - height: 29.9 cm - weight: 2.8 kg , With stand - width: 47.7 cm - depth: 17 cm - height: 35.7 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80%
