The HP 1910 Switch Series, part of the HP OfficeConnect portfolio, delivers Fast Ethernet connectivity for cost-conscious smaller organizations. The switches are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The 1910 Switch Series are advanced smart-managed fixed configuration switches in an easy-to-administer solution. Customizable features include basic layer 2 features like VLANs and link aggregation as well as advanced features such as Layer 3 static routing and ACLs.
Simplifies Network Deployment and Management for Small Organizations
The HPE 1910 Switch Series features easy-to-use, out-of-the box, plug-and-play deployment.Series offers a complete portfolio of choices for increased flexibility. It consists of five rack-mountable models with internal power supplies including three non-Power over Ethernet (PoE) models: 8-, 24- and 48-port and two PoE+ models: 8- and 24-port. All models come with two combo uplink ports.These smart-managed switches use an intuitive Web management interface to simplify deployment and management while offering you greater granularity of control of key features. -
Keeps Your Business up and Running and Protected
Enhanced security features such as Access Control List, IEEE 802.1x and VLANs guard your network from unwanted or unauthorized access.Management security restricts access to critical configuration commands, offers multiple privilege levels with password protection, and supports secure http (https).The 1910 Switch Series is covered by the Hewlett Packard Enterprise Limited Lifetime Warranty. -
Delivers Improved Performance, While Lowering Total Cost of Ownership (TCO)
The HPE 1910 Switch Series delivers advanced functionality in smart-managed switches, including Layer 3 static routes, SFP ports, IPv6 support, rate limiting, link aggregation, and IGMP.The switch series includes PoE+ options to power IP devices without the cost of additional power outlets.Advanced silicon technology delivers greater energy-efficiency and the Limited Lifetime Warranty significantly reduce TCO.
- HPE 1910-48G Switch - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L3 - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x SFP
- MAC Address Table Size
- 8K entries
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 2, SNMP, SNMP 3, SNMP 2c, HTTP, HTTPS
- Flow control, Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 26 cm x 4.3 cm
- 3.1 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8K entries
- Routing Protocol
- Static IP routing
- Authentication Method
- RADIUS
- Processor
- 1 x ARM: 333 MHz
- RAM
- 128 MB
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
- Voltage Required
- Rack Mounting Kit
- Included
- VCCI, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, UL 60950, ICES-003 Class A, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC Part 15 A
- 44 cm
- 26 cm
- 4.3 cm
- 3.1 kg
- 0 °C
- 45 °C
- 10 - 90%
