HP's first color MFP with TopShot scanning lets you scan, copy, and print with ease. Use HP TopShot scanning to capture images of 3D objects, and then use business apps to send directly to the web.
Experience a new, amazingly simple way to scan. Just place a 3-D object or document on top of your MFP and hit Scan--for remarkable, ready-to use digital images.
Capture images of 3D objects and scan everyday documents
- Scan images of 3D objects and post directly to the Web.5 And easily remove background via HP Scan Software
- Enjoy color multifunction performance with convenient, reliable printing and copying
- Take advantage of one-step operation and easily scan a variety of objects, documents, and images
Stay connected with innovative Web-connected printing5
- Capture images of 3D objects, then use an app to post directly to popular auction sites.5
- Use convenient Web apps to scan documents and images directly to online storage sites.5
- Stay connected and in touch by scanning business cards directly to address books.
- Access the Web directly without a PC and get a wide range of business apps.5
Stay productive--both on the go and in the office
- HP ePrint--now you can print from virtually anywhere.2
- Stay connected--share on a wireless network,3 or even print from a mobile device without using a network.4
- Now with AirPrint™. Simply print wirelessly from your iPad™, iPhone®, and iPod touch®.6
Set up quickly, stay up and running easily
- Access, store, and print with the tap of a finger, using the 3.5-in. (8.9 cm) color touchscreen display.
- Install in just a few minutes--there's no CD required with HP Smart Install.7
- Print from anywhere in the office with wireless networking3 and share resources using built-in Ethernet.
Eco-Highlights
- Save energy--HP Auto-Off Technology turns your printer Off when you don't need it.1
- Reduce energy use with Instant-on Technology.2
- Free, convenient cartridge recycling in 54 countries.
WHAT IS HP TOPSHOT SCANNING?
HP TopShot Scanning is a revolutionary technology included with the HP LaserJet Pro 200 color MFP M275. Now it's easy to quickly capture high-quality images of your documents--and even 3-D objects--for immediate use in your printed materials or on the web.
This new category of HP LaserJet MFP (multifunction product) features a camera embedded into a hinged arm that is elevated above the capture stage of the device. The camera uses a high-quality optical lens and a high-resolution sensor to capture an image of any document up to 216 by 297 mm, A4 (8.5 by 11 in, letter) or any small object. A total of six images are captured per scan or copy-- three with flashes from different angles and three in ambient light conditions with different exposure levels--producing virtually glare-free and shadow-free images. These separate shots are then automatically combined into one seamless image of exceptional quality. With HP TopShot Scanning, you'll see images similar to or better than those captured by your hand-held digital still camera and with better depth-of-focus than images from a flatbed scanner.
HP ePrint. Now print from virtually anywhere!
With HP ePrint mobile printing, there's no need to wait to print on the go. Simply send the prints you want directly to an HP ePrint enabled printer, using a smartphone, notebook, or other mobile device.¹ Stay productive and connected on the go -- print emails, photos, business materials, and more. Now you can access and print content when and where you need it.
HP ePrint Wireless Direct Printing
Easily print and share using wireless networking, and stay connected to the content you need. Plus, you can print from wireless-enabled smartphones and mobile devices -- without a network -- using HP ePrint wireless direct printing.²
Apple AirPrint™
HP ePrint-enabled printers -- now with AirPrint. Simply print wirelessly from your iPad®, iPhone®, and iPod touch®.³
1.Measured using ISO/IEC 24734, excludes first set of test documents. For more information see http://www.hp.com/go/printerclaims. Exact speed varies depending on the system configuration, software application, driver, and document complexity.
2.Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions, see http://www.hp.com/go/mobile-printing-solutions.
3.Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
4.Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at http://www.hp.com/go/eprintcenter.
5.Requires a wireless access point and an Internet connection to the printer. Services may require registration. App availability varies by country, language, and agreements. For details,
6.Supports iOS 4.2 and later devices (iPad®, iPhone® 4, iPhone® 3GS, and 3rd and 4th generation iPod touch®) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint™ and iOS 4.2 and later devices require an 802.11 "wireless network" connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple® Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
7.HP Smart Install works with Windows® only.
8.Requires an Internet connection to the printer. Services may require registration. App availability varies by country, language, and agreements. For details, http://www.hp.com/go/eprintcenter.
Capture images of 3-D objects and scan everyday documents
Capture high-quality images of 3-D objects easily, without need of a special setting or lighting, and easily remove background distortion via HP Scan Software.A camera embedded into a hinged arm captures high quality images of any document up to A4 or any small 3D object, ready for use in online sales.Enjoy outstanding colour multifunction performance with convenient, reliable printing and copying.Take advantage of one-step operation and easily scan a variety of objects, documents, and images. -
Stay connected with innovative web-connected printing
Simplify your business with convenient workflow apps – scan documents and images directly to online storage sites.Access information, store images and manage your entire workflow directly from the printer with the easy-to-use, intuitive 8.9 cm (3.5-inch) colour touchscreen display.Access the web directly without a PC and get a wide range of business apps for archiving, printing forms, reading news, and more. -
Stay productive – both on the go and in the office
Now you can print from virtually anywhere with HP ePrint. Print directly to your HP printer using a smartphone, notebook, or other mobile device.Easily print and share using wireless networking and you can print from wireless-enabled smartphones and mobile devices, without a network, using wireless direct printing.Simply print wirelessly from your iPad , iPhone , and iPod touch with AirPrint . -
Set up quickly and stay up and running with advanced, easy-to-use features
Install the MFP in just a few minutes – there's no CD required with HP Smart Install.Print from anywhere in the office with wireless networking.Connect your MFP to PCs and easily share resources to improve office efficiency, using built-in Ethernet.
- HP TopShot LaserJet Pro M275 MFP - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 20000 impressions
- Recommended Monthly Volume
- 250 - 950 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Display
- 3.5"
- Original Size
- 216 x 297 mm (max)
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- 8 megapixel optical scan resolution, HP TopShot Scanning
- Power
- AC 230 V
- 46.8 cm x 40.9 cm x 27 cm
- 13.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 20000 impressions
- 250 - 950 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB 128 MB
- Max Supported Memory
- 128 MB 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- Image Enhancement Technology
- HP ImageREt 2400
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 27.5 sec
Scanning
- Scan Element
- CMOS
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- 150 sheets
- 50 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 16 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Copying: up to 16 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- SNMP, HTTP, HTTPS
- SSL, WEP, TLS, WPA, WPA2, TKIP, AES
- Operating System Support
- MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, Apple Mac OS X 10.5, MS Windows 7, Ubuntu Linux 8.04 LTS, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V
- 310 Watt
- Power Consumption Standby
- 10.8 Watt
- Power Consumption Sleep
- 5.1 Watt
- First Copy Out Time B/W
- 29 sec
- First Copy Out Time Colour
- 48.5 sec
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- ENERGY STAR Certified
- 46.8 cm
- 40.9 cm
- 27 cm
- 13.5 kg
- Shipping Width
- 59.7 cm
- Shipping Depth
- 40.8 cm
- Shipping Height
- 39.7 cm
- Shipping Weight
- 17 kg
- Sound Emission
- 50 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
