HP t410 Smart Zero Client, Cortex-A8, 1GB, 512MB, 1920 x 1080 resolution
Quicklinx: 8C0XWS00 Mfr#: H2W23AA#ABU
Zero management. Zero configuration. Zero compromise. Built with intuitive, auto-sensing technology for client virtualization environments that demand PC-like performance with simple deployment set-up and flexible protocol support.
  • Dual display connections
    Featuring support for a native dual-digital monitor set-up through integrated DisplayPort and VGA connectors. Experience HD quality with single or dual display resolutions up to 1920x1200.
  • Impressive performance, innovative design
    Maintain PC-like performance in a small footprint with a Texas Instruments TMS320DM8148 ARM Cortex processor, 1 GB DDR3 SDRAM and 4 GB eMMC Flash memory capacity.Featuring DSP Acceleration for RemoteFX, PCoIP and ARM Neon extensions for Citrix HDX System on a Chip (SoC) for a powerful, flexible user experience.
  • HP Smart Zero Client technology
    Automatic Intelligence, inherited by HP Smart Zero Client Services, establishes a secure desktop environment for all devices in minutes, and downloads everything it needs to deliver a robust user experience.If your client virtualization software changes your HP Smart Client will adapt to your environment. Simply repurpose your HP Smart Client for another protocol, saving time and money.
  • HP Velocity
    Reduce poor network connectivity in densely populated work environments with HP Velocity, a new HP feature. As network conditions change, HP Velocity reacts to maintain the highest quality performance.
  • Eco-highlights
    Benefit from traditional, PC-like performance and multimedia playback while using less energy. ENERGY STAR certified and EPEAT Gold registered. Low halogen materials and post-consumer recycled plastics greater than 10%.
HP Smart t410 - DTS - Cortex-A8 1 GHz - 1 GB - flash 2 GB
Zero client - desktop slimline
1 x ARM Cortex-A8 1 GHz
Cache Memory
256 KB L2 Cache
Cache Per Processor
256 KB
RAM
1 GB DDR3 SDRAM
Hard Drive
Flash 2 GB
Optical Storage
No optical drive
Audio Output
Stereo - integrated
GigE
OS Provided
Software Included
VMware View Client, Citrix ICA 12.0, HP Device Manager, Microsoft RDP 7.1
14.8 cm x 18.5 cm x 3.2 cm
638 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Zero client
Recommended Use
Small business, corporate business
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
ARM Cortex-A8
Clock Speed
1 GHz
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 256 KB
Cache Per Processor
256 KB
RAM
Installed Size
1 GB
DDR3 SDRAM
Effective Memory Speed
400 MHz
Hard Drive
Flash
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Mouse
USB
Integrated
Wake on LAN (WoL), DHCP support
4 x USB 2.0 (2 front, 2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x VGA
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm
VCCI, EN 61000-3-2, EN55022, ZH1 618, EN 61000-3-3, EN55024, FCC, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
Power adapter
Power Provided
24 Watt
Operating System / Software
OS Provided
Software
ENERGY STAR Certified
14.8 cm
18.5 cm
3.2 cm
638 g
10 °C
35 °C
5 - 95% (non-condensing)
