The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are simple and pain-free with drag and drop file access. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
- HP RDX Removable Disk Backup System - RDX drive - Hi-Speed USB - with 160 GB Cartridge
- RDX drive
- Enclosure Type
- Internal
- Interface
- Hi-Speed USB
- 14.68 cm x 17.07 cm x 4.14 cm
- 635 g
- Storage Removable
- RDX - 5.25" x 1/2H
- Media Type
- RDX - 5.25"
- Data Transfer Rate
- 30 MBps (external) / 480 MBps (internal)
- Microsoft Certification
- Compatible with Windows 7
- Bundled with
- 160 GB Cartridge
- Designed For
- ProLiant DL370 G6, MicroServer, ML110 G3, ML110 G3p, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G5, ML150 G6, ML310 G3, ML310 G4, ML310 G5, ML330 G6, ML350 G5, ML350 G6, ML370 G5, ML570 G4; Workstation xw4300, xw4400, xw4550, xw4600, xw6400, xw6600, xw8400, xw8600, xw9300, xw9400
- RDX drive
- Enclosure Type
- Internal
- Interface
- Hi-Speed USB
- 14.68 cm
- 17.07 cm
- 4.14 cm
- 635 g
- Bundled with
- 160 GB Cartridge
Storage Removable
- Media Type
- RDX - 5.25"
- Average Seek / Access Time
- 15 ms
- 1 x Hi-Speed USB - 4 PIN USB Type B
- Compatible Bays
- 1 x front accessible - 5.25" x 1/2H
- Media Included Qty
- 1
- Cables Included
- 1 x USB cable
- MTBF
- 550,000 hours
- VCCI, C-Tick, EN 60950, IEC 60950, UL 60950, CISPR 22, FCC
- 6.6 Watt
- Software Included
- Drivers & Utilities, HP RDX Continuous Data Protection Software
- 5 °C
- 45 °C
- 20 - 80% (non-condensing)
- Designed For
- HP ProLiant DL370 G6 Base, DL370 G6 High Performance, MicroServer, ML110 G3, ML110 G3p, ML110 G4, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G2, ML310 G3, ML310 G4, ML310 G5, ML330 G6, ML350 G4, ML350 G4p, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML570 G4, ML570 G4 High Performance , HP Workstation xw4100, xw4200, xw4300, xw4400, xw4550, xw4600, xw6000, xw6200, xw6400, xw6600, xw8000, xw8200, xw8400, xw8600, xw9300, xw9400
