Do you need a direct attached or shared storage solution within your BladeSystem enclosure? The D2200sb Storage Blade delivers direct attached storage for c-Class servers, with support for up to twelve SFF SAS hard disk drives or SAS/SATA SSDs or SATA Midline hard drives. The enclosure backplane provides a PCI Express connection to the adjacent c-Class server blade and enables high performance storage access without any additional cables. The D2200sb features the onboard Smart Array P410i controller with 1 GB flash-backed write cache, for increased performance and data protection. Use the HP StoreVirtual VSA to turn the D2200sb into an iSCSI SAN for use by all severs in the enclosure and any server on the network. VSA includes remote replication capabilities, thin provisioning, and snapshot. Combine the D2200sb with the HP X1800sb Network Storage Blade to enable file serving iSCSI shared storage inside the BladeSystem enclosure.
High-Performance Direct Attached Storage
The HPE D2200sb Storage Blade supports twelve universal small form factor hot-plug SAS hard disk drives (or SAS/SATA SSDs or SATA Midline hard disk drives) which expand the spindle count for the adjacent blade server.High-speed PCI Express (PCIe) connection to adjacent c-Class server blade provides peak DAS performance.The D2200sb Storage Blade includes an HPE Smart Array P410i controller 1 GB flash-backed write cache, for increased performance and data protection. -
Internal Shared Storage
Build scalable internal shared storage with the D2200sb Storage Blade and HPE StoreVirtual VSA. Storage can scale within the same c-Class BladeSystem enclosure or across enclosures via iSCSI.The HPE StoreVirtual VSA provides a scalable iSCSI SAN based on a clustered storage architecture, and includes remote replication capabilities, thin provisioning, and snapshots.Expand capacity by adding D2200sb and HPE StoreVirtual VSA within the same enclosure or to additional enclosures. -
Compact yet Flexible
The D2200sb Storage Blade plugs directly into any c-Class enclosure with no additional cabling needed, providing dedicated storage for the adjacent server blade.The Smart Array P410i controller supports RAID 0, 1, 1+0, 5, 6 with Advanced Data Guarding (ADG) for a choice of RAID options.The D2200sb supports twelve drive bays with SAS /SATA/SSD technology where you can choose from a range of small form factor (SFF) drives. -
Familiar ProLiant Management
Simple configuration: Use the browser-based Array Configuration Utility (ACU) to configure your array, add additional disk drives to an existing configuration, or completely reconfigure your disk drive array.Receive hard drive pre-failure alerts: Manage the D2200sb and receive hard drive pre-failure alerts through HPE Systems Insight Manager.Manage storage remotely: Manage your D2200sb remotely using the adjacent blade server's integrated Light's Out (iLO) technology.
- HPE StorageWorks D2200sb PCIe Storage Blade - hard drive array
- Hard drive array
- Total Array Capacity
- 7.2 TB
- Interface
- SAS 6Gb/s
- Installed Devices / Modules Qty
- 12 (max)
- Supported Drives
- SAS-2
- Storage Controller
- RAID (SAS 6Gb/s) - RAID RAID 0, 5, 6, 10, ADG
- Hard Drive
- No HDD
- 18.1 cm x 51.6 cm x 5.3 cm
- 3.9 kg
- 3-year warranty
- Designed For
- Integrity BL860c i4; ProLiant BL660c Gen8, BL660c Gen8 Performance, WS460c Gen8
- Hard drive array
Chassis
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SAS-2
Storage
- 7.2 TB
- HDD Array External Interface
- SAS 6Gb/s
Storage Controller
- RAID
- Interface Type
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Cache / Buffer Size (Max)
- 1 GB
- Max Storage Devices Qty
- 32
- RAID Level
- RAID 0, RAID 5, RAID 6, RAID 10, ADG
Hard Drive
- No HDD
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" SFF
- 18.1 cm
- 51.6 cm
- 5.3 cm
- 3.9 kg
- Limited warranty - parts and labour - 3 years - on-site
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- Designed For
- HPE Integrity BL860c i4 , HPE ProLiant BL660c Gen8, BL660c Gen8 Performance, WS460c Gen8
