Your basket is empty
HP SCANJET PROFESSIONAL 3000 sheet feed scanner
Quicklinx: 772LWS00 Mfr#: L2723A#B19
  • Compatible with Windows 7
Scan business documents from your desktop, using a fast, reliable, sheet-feed scanner. Scan two-sided documents at up to 20 pages per minute, using the 50-page automatic document feeder, and catch misfed pages with ultrasonic double-feed detection.
Digitize documents with fast, two-sided scanning.
  • Scan up to 20 ppm/40 ipm at 300 dpi in black and white, grayscale and color.
  • Scan up to 50 pages at a time while tending to other projects--just press Scan and walk away.
  • Archive files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.[1]
  • Scan and organize business cards using NewSoft Presto! BizCard Reader software.[1]
Easily convert your hard copies to digital files.
  • Scan with the touch of a button.
  • Integrates with leading content management applications using the TWAIN software driver.
  • Capture all the detail and fine print at up to 600 dpi scanning resolution.
  • Scan in different file formats--PDF, TIFF, JPEG, Microsoft Word--and save disk space with smaller file sizes.
Count on reliable document capture and HP support.
  • Reliably scan every page of your document, using ultrasonic double-feed detection.
  • Tackle a variety of paper types, thicknesses and sizes reliably.
  • Rely on this scanner to work hard for you every day with a duty cycle of up to 1000 pages per day.
  • Get a one-year limited warranty and the support and services of HP Total Care.
Save energy with Instant-on scanning technology Reduce clutter and waste--scan and share documents digitally Uses 50% less packaging than previous model
ENERGY STAR® Qualified
http://www.hp.com/ecosolutions
HP ScanJet Professional 3000 - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
215.9 x 863.6 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
215.9 mm x 863.6 mm
Supported Document Type
Plain paper, business card, plastic card, check, labels
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
AC 120/230 V ( 50/60 Hz )
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5
Microsoft Certification
28.6 cm x 15.3 cm x 16.2 cm
2.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
215.9 x 863.6 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Contact Image Sensor
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Control Panel Buttons Functions
Scan, cancel
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - black & white - A4 - 200 dpi , 20 ppm - colour - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
215.9 mm x 863.6 mm
50 sheets
USB 2.0
1 x USB cable
External power adapter
Power Consumption Operational ( Standby )
11.38 Watt
Software Included
Drivers & Utilities, Nuance PaperPort, Nuance OmniPage, Presto! BizCard SE
28.6 cm
15.3 cm
16.2 cm
2.3 kg
10 - 80%
