HP Scanjet Pro 2500 f1 Document Scanner
Quicklinx: BT5QWS00 Mfr#: L2747A#B19
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Enhance productivity for routine scanning with a compact HP ScanJet Pro. Automate workflow with fast, two-sided scanning, a 50-page ADF, 1,500-page daily duty cycle, and one-button shortcuts. You can even quickly capture and edit text from documents.
  • Boost productivity with fast, versatile scanning
    Produce up to 40 images per minute with two-sided scanning and a 50-page automatic document feeder.Scan pages up to 21.6 cm x 309.9 cm (8.5 x 122 inches) through the ADF, and use the flatbed for bulky media.Don't wait for warm-up – Instant-on Technology lets you begin scanning quickly.Free up space for work. This HP ScanJet is small and slim – a modern design perfect for the desktop.
  • Automate and streamline your workflow
    Streamline routine work with one-touch scanning – create one-button, custom settings for recurring scan jobs.Define scan profiles for common document types and scan to multiple destinations with HP Scan software.Quickly share or archive scans directly to popular cloud destinations with HP Scan software.Scan directly into applications without opening another program with HP's full-featured TWAIN driver.
  • Sharp images and powerful editing tools
    Accurately capture text from documents for easy editing with HP Scan and I.R.I.S. Readiris Pro OCR software.Get sharp, true-to-life scans of documents, graphics, and photos with up to 1200 dpi resolution.Easily edit and organise documents and photos with a full suite of feature-rich software.Auto-imaging features in the included HP Scan software let you Enhance images and delete blank pages.
HP Scanjet Pro 2500 f1 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS / CIS
Light Source
LED
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
45.1 cm x 35.1 cm x 12.2 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 3100 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Control Panel Buttons Functions
Scan, cancel, duplex
Duty Cycle
1500 scans per day
Scanner Speed Details
20 ppm - 300 dpi , 40 ipm - duplex - 300 dpi (front) / 300 dpi (back)
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Supported Document Size Details
ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
C-Tick, BSMI, CISPR 24, cUL, EN 61000-3-2, EN55022, ICES-003, SASO, EN 61000-3-3, CISPR 22, CCC, EMC, RoHS, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1 Second Edition, KN22, EAC, TER, PVOC, CoC
ENERGY STAR Certified
External power adapter
Power Consumption Stand by
4.73 Watt
Power Consumption Sleep
1.68 Watt
Software Included
Readiris Pro, Cardiris, ArcSoft PhotoStudio, Nuance PaperPort, HP Scan, HP Scanner Tools Utility
System Requirements Details
Windows 7/8/8.1/10 - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.9/10.10 - RAM 1 GB
45.1 cm
35.1 cm
12.2 cm
4.3 kg
Shipping Width
54.8 cm
Shipping Depth
46.5 cm
Shipping Height
19.4 cm
Shipping Weight
6.1 kg
Limited warranty - 1 year
10 °C
35 °C
15 - 80% (non-condensing)
