Enhance workteam productivity – share a range of advanced document capture tools over your wired Ethernet network. This PC-connected scanner lets you scan multi-page documents – single or double-sided – and share to networked folders or via email.
Share robust, versatile performance across multiple users via integrated networking
Share advanced scanning tools between multiple users – just connect to an existing Ethernet network, no IT expertise necessary. Easy sharing and sending of digital files direct from the scanner. Optional PIN security. ISIS , TWAIN and WIA drivers. -
Scan multi-page documents quickly and reliably with the duplex automatic document feeder
Boost office productivity with unattended document capture. Load up to 50-sheets into the automatic document feeder and scan at up to 15 ppm/6 ipm. Handle business cards, stapled documents, photos and slides/negatives using the flatbed scanner. -
Streamline your scanning processes with easy shortcuts and automatic image enhancement
Improve efficiency with a task-based user interface and one-touch 'scan' and 'copy' buttons. Set shortcuts to common tasks such as scan-to-PDF. Automatically deskew, crop and rotate, and choose colour drop-out to improve OCR accuracy.
- HP ScanJet N6350 Networked Document Flatbed Scanner - flatbed scanner - USB 2.0, LAN
- Flatbed scanner
- Interface Type
- USB 2.0, LAN
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 220 x 356 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Optical Resolution
- 2400 dpi x 2400 dpi
- Scan Speed
- 15 ppm
- Max Document Size
- 216 mm x 292 mm
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
- Microsoft Certification
- Certified for Windows Vista
- 50.2 cm x 41.5 cm x 16.8 cm
- 6.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Flatbed scanner
- Interface Type
- USB 2.0, LAN
- 220 x 356 mm
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- CCD
- Scan Speed
- 15 ppm
- Control Panel Buttons Functions
- Scan, copy, cancel, setup
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 292 mm
- Supported Document Size Details
- ADF - up to 220 x 356 mm , Flatbed - up to 216 x 292 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B , LAN
- Included Accessories
- Transparency adaptor
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities, Readiris Pro, ScanSoft PaperPort, Presto! BizCard
- OS Required
- Additional Requirements
- CD-ROM, SVGA monitor
- 50.2 cm
- 41.5 cm
- 16.8 cm
- 6.7 kg
- Shipping Width
- 58.8 cm
- Shipping Depth
- 54.7 cm
- Shipping Height
- 24.8 cm
- Shipping Weight
- 8.2 kg
- 10 °C
- 35 °C
- 15 - 80%
