HP Scanjet 200 Flatbed Scanner
Quicklinx: 91FDWS00 Mfr#: L2734A#B19
Capture high-quality images and start sharing quickly. Scan at high resolution, edit photos, and save documents to digital files. One-touch scan-to buttons let you start working fast. Place this compact, easy-to-use scanner almost anywhere.
  • Experience high-quality photo and document scanning
    Scan important photos and get precise results. Capture crisp image detail at up to 2400 x 4800 dpi resolution, 48-bit colour.Enjoy fast, convenient scanning of photos and images to Internet sharing sites.Scan important paperwork, photos, and everyday documents into easy-to-access digital files.Finish jobs faster – scan a 10 x 15 cm (4 x 6-inch) photo in as fast as 21 seconds at 200-dpi resolution .
  • Start working fast with easy-to-use functions and quick setup
    Create the prints you need: use the ArcSoft PhotoStudio 6 photo-editing software included to easily edit, search, and organise images for printing in multiple sizes.Save time with convenient one-touch scanning capabilities. Capture and send images directly to email or PDF – and print or copy images with just a touch.Get to work quickly with an intuitive interface with easy-to-use controls. Plug in and set up fast with a single cable.
  • Save space: this compact scanner fits almost anywhere you need it
    Set up and work where you want-this compact, landscape-oriented scanner can fit almost anywhere in your home or office.Scan books, magazines, and bound materials with ease, using the scanner's floating-hinged lid for high clearance.Eliminate the need for a power cable – this USB-powered scanner saves energy by plugging directly into your PC.
HP ScanJet 200 Flatbed Photo Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Additional Functions
Email
Max Supported Document Size
216 x 297 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Interpolated Resolution
19200 dpi
Scan Speed
14 sec / scan
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, photo
Duty Cycle
26000 scans per day
Microsoft Windows XP SP2 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple MacOS X 10.8 or later
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
Email
216 x 297 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
19200 dpi
Bulb / Light Source Type
LED
Scan Speed
14 sec / scan
Duty Cycle
26000 scans per day
Scanner Speed Details
14 sec/scan - preview
Scanner Features
Powered by USB port
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper, photo
Interfaces Details
USB 2.0
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
2.5 Watt (0.5 Watt)
Software Included
Drivers & Utilities, ArcSoft PhotoStudio 6
System Requirements Details
Windows 7/Vista - 1.3 GHz - RAM 1 GB - HD 1 GB , Windows 7 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 1 GB , Windows Vista 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 2 GB , Windows XP SP2 or later - 1.3 GHz - RAM 512 MB - HD 600 MB
Shipping Width
43.4 cm
Shipping Depth
33.5 cm
Shipping Height
8.6 cm
Limited warranty - 1 year - response time: next business day , Technical support - phone consulting - 1 year
10 °C
35 °C
15 - 80% (non-condensing)
