Capture high-quality images and start sharing quickly. Scan at high resolution, edit photos, and save documents to digital files. One-touch scan-to buttons let you start working fast. Place this compact, easy-to-use scanner almost anywhere.
Experience high-quality photo and document scanning
Scan important photos and get precise results. Capture crisp image detail at up to 2400 x 4800 dpi resolution, 48-bit colour.Enjoy fast, convenient scanning of photos and images to Internet sharing sites.Scan important paperwork, photos, and everyday documents into easy-to-access digital files.Finish jobs faster – scan a 10 x 15 cm (4 x 6-inch) photo in as fast as 21 seconds at 200-dpi resolution . -
Start working fast with easy-to-use functions and quick setup
Create the prints you need: use the ArcSoft PhotoStudio 6 photo-editing software included to easily edit, search, and organise images for printing in multiple sizes.Save time with convenient one-touch scanning capabilities. Capture and send images directly to email or PDF – and print or copy images with just a touch.Get to work quickly with an intuitive interface with easy-to-use controls. Plug in and set up fast with a single cable. -
Save space: this compact scanner fits almost anywhere you need it
Set up and work where you want-this compact, landscape-oriented scanner can fit almost anywhere in your home or office.Scan books, magazines, and bound materials with ease, using the scanner's floating-hinged lid for high clearance.Eliminate the need for a power cable – this USB-powered scanner saves energy by plugging directly into your PC.
- HP ScanJet 200 Flatbed Photo Scanner - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Additional Functions
- Max Supported Document Size
- 216 x 297 mm
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 48-bit colour
- Optical Resolution
- 2400 dpi x 4800 dpi
- Interpolated Resolution
- 19200 dpi
- Scan Speed
- 14 sec / scan
- Max Document Size
- 216 mm x 297 mm
- Supported Document Type
- Plain paper, photo
- Duty Cycle
- 26000 scans per day
- System Requirements
- Microsoft Windows XP SP2 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple MacOS X 10.8 or later
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 216 x 297 mm
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- 19200 dpi
- Bulb / Light Source Type
- LED
- Scan Speed
- 14 sec / scan
- Duty Cycle
- Scanner Speed Details
- 14 sec/scan - preview
- Scanner Features
- Powered by USB port
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 297 mm
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Consumption Operational (Standby)
- 2.5 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, ArcSoft PhotoStudio 6
- OS Required
- System Requirements Details
- Windows 7/Vista - 1.3 GHz - RAM 1 GB - HD 1 GB , Windows 7 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 1 GB , Windows Vista 64-bit Edition - 1.3 GHz - RAM 2 GB - HD 2 GB , Windows XP SP2 or later - 1.3 GHz - RAM 512 MB - HD 600 MB
- Shipping Width
- 43.4 cm
- Shipping Depth
- 33.5 cm
- Shipping Height
- 8.6 cm
- Limited warranty - 1 year - response time: next business day , Technical support - phone consulting - 1 year
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
