Your basket is empty
The NVIDIA Quadro NVS 295 high resolution dual-display business graphics solution, designed for small form factor systems, delivers reliable hardware and software for a stable business environment. Tested on leading business applications, Quadro NVS 295 is capable of driving up to two 30" displays at 2560 x 1600 resolutions and is designed to meet the needs of today's most demanding business user.
NVIDIA Quadro NVS 295 graphics card - Quadro NVS 295 - 256 MB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
256 MB - GDDR3
Max Resolution
2560 x 1600
2 x DVI-D (dual link) - with adapter , 2 x DisplayPort
API Supported
DirectX 10, OpenGL 3.0
16.8 cm x 6.9 cm
3 years warranty
HP 6000 Pro, 6005 Pro, 6200 Pro, 8200 Elite (CMT, micro tower, SFF), Elite 8000 (CMT, SFF), Elite 8100 (SFF); Business Desktop dc7900 (CMT, SFF); Workstation xw4600, xw9400, z200, z210, z400, z600, z800
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Max Resolution
2560 x 1600
API Supported
Nvidia CUDA technology
Size
256 MB
GDDR3 SDRAM
23 Watt
2 x DisplayPort-DVI adapter
16.8 cm
6.9 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
HP Workstation xw4600, xw9400, z200, z210, z400, z600, z800 , HP Compaq 6000 Pro, 6005 Pro, 6200 Pro, 8200 Elite (CMT, micro tower, SFF), Elite 8000 (CMT, SFF), Elite 8100 (SFF) , HP Compaq Business Desktop dc7900 (CMT, SFF)
