Support your virtualization environment with the HP t510 Thin Client – a significant upgrade performance with built-in energy efficiency, smart connectivity features and easy set-up guides for your PC-like multimedia needs.
Advanced performance
The HP t510 Thin Client features a dual-core processor and DDR3-1066 SDRAM memory – built for a high grade end-user experience. -
Windows-based support
Experience broad application flexibility with a range of embedded operating system choices including versions of Microsoft Windows Embedded systems and HP's ThinPro Linux distribution. All support the security and experience expected for a thin client with write filters, local applications, a full browser, and terminal emulation. -
Convenient connectivity
The HP t510 features 6 USB 2.0 ports, a serial port, parallel port and power cord retention clip. Sustain wireless connectivity anywhere your network reaches with enterprise-ready integrated WiFi models. -
HP Velocity for your network
Improve network performance and the end-user experience with HP Velocity software. -
Integrated management
Store critical data on a secure centralized server or add Smart Cards for added security. HP Easy Tools guides users through set-up to Microsoft, Citrix, and VMware applications. Utilize HP Device manager, an enterprise-class thin client management software that allows you to view and change assets remotely. -
Eco-highlights
HP t510 Flexible Series Thin Clients are built with the environment in mind: low halogen components, Post-Consumer Recycled Plastics > 20% (excluding PCB), ENERGY STAR qualified, EPEAT Gold registered. -
HP service and dependability
Easy setup, easy manageability and now easy maintenance. With HP t510 Thin Clients, you can select from a range of HP Care Pack Services for support beyond standard.
- HP Flexible t510 - tower - Eden X2 U4200 1 GHz - 4 GB - flash 1 GB
- Thin client - tower
- Localisation
- Processor
- 1 x VIA Eden X2 U4200 / 1 GHz (Dual-Core)
- RAM
- 4 GB (installed) / 4 GB (max) - DDR3 SDRAM - PC3-8500
- Hard Drive
- Flash 1 GB
- Optical Storage
- No optical drive
- Graphics Controller
- VIA ChromotionHD 2.0
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP Smart Zero Technology
- Software Included
- Citrix ICA, Rdesktop 1.6, Mozilla Firefox, Citrix ICA 12.0, HP Remote Graphics Software Receiver 5.x
- 5.84 cm x 21.59 cm x 21.97 cm
- 1.49 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Thin client
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- VIA Eden X2 U4200
- Clock Speed
- 1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
- Chipset Type
- VIA VX900
RAM
- Installed Size
- 4 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1066 MHz
- Memory Specification Compliance
- PC3-8500
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- Flash
- Capacity
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- Slots
- 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card
- 6 x USB 2.0 (2 front, 2 rear) , 1 x serial , 1 x parallel , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x microphone , 1 x DVI-I , 1 x DVI-D
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Microsoft Windows Server 2000 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5.84 cm
- 21.59 cm
- 21.97 cm
- 1.49 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
