Give your HP Pro PC content room to roam on the extra-large HP ProDisplay P242va Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity needs at a highly affordable price point.
Fabulous front-of-screen
Get crisp image clarity for all your content on the 61 cm (24") diagonal screen with 1920 x 1080 resolution and 3000:1 contrast ratio. 178-degree viewing angles mean everybody has a great view of the screen. -
High-speed connection for FHD imagery
Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple monitor connections from a single PC. Get legacy device compatibility from the VGA connector. -
Create an efficient, easy-to-use workspace
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
- HP ProDisplay P242va - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 57.12 cm x 19.12 cm x 41.64 cm
- 3.6 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27675 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 96 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese, Korean
- HDCP
- Black
- 57.12 cm x 19.12 cm x 41.64 cm - with stand
- 3.6 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, dual display support, cable routing slots, VESA 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 57.12 cm - depth: 19.12 cm - height: 41.64 cm - weight: 3.6 kg , Without stand - width: 57.12 cm - depth: 5.5 cm - height: 35.55 cm - weight: 2.85 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
