HPE PROCURVE ZL 20X GIG-T + 4X GBI
Quicklinx: 4NP0WS00 Mfr#: J8705A
The Switch 5400zl Series consists of the most advanced intelligent edge switches. The foundation for this switch is a purpose-built, programmable ProVision ASIC that allows the most demanding networking features, such as QoS and security, to be implemented in a scalable yet granular fashion. With a variety of Gigabit interfaces, integrated PoE on all 10/100/1000Base-T ports, and a choice of form factors, the 5400zl switch offers excellent investment protection, flexibility, and scalability, as well as ease of deployment, operation, and maintenance.
HPE 20p 10/100/1000 + 4p Mini-GBIC Module - expansion module - Gigabit Ethernet x 20
Expansion module
Plug-in module
Ports
20.7 cm x 26.2 cm x 4.5 cm
1 kg
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
4 x SFP (mini-GBIC)
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
HP Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge; HPE 3500-24G-PoE yl Switch, Switch 5406zl Intelligent Edge; HPE Aruba 5406 zl
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Auxiliary Ports
4 x SFP (mini-GBIC)
Data Transfer Rate
1 Gbps
Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
Expansion Slots
4 (total) / 4 (free) x SFP
20 x 1000Base-T (PoE) - RJ-45
Compatible Slots
1 x Expansion Slot
20.7 cm
26.2 cm
4.5 cm
1 kg
HP Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge , HPE 3500-24G-PoE yl Switch, Switch 5406zl Intelligent Edge , HPE Aruba 5406 zl
4NP0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
