Work smarter – and look good doing it – with an HP ProBook built to perform wherever business takes you. Count on a durable design inside and out, with integrated security and a spill-resistant keyboard. Plus, there's less bulk to bring with you, thanks to thin, stylish construction.
Powerful productivity
Take charge of your workday with the latest technologies like ac band WLAN, optional hybrid hard drive, and 4th generation Intel Core processors.An optional 500 GB hybrid hard drive offers the storage capacity of a traditional hard drive and the responsiveness of hybrid hard drive.Don't let the office tie you down. Work in more places with high-speed wireless connectivity, including optional ac band WLAN and Bluetooth 4.0.You have to be quick. The speed of the latest 4th generation Intel Core i3/i5/i7 processors help you work faster. -
It's all about connections
Easily share your internet connection with up to five devices with HP Wireless Hotspot. Help colleagues get online and improve productivity. Print from your PC, smartphone, or tablet from virtually anywhere with HP ePrint.Make the most of virtual conferencing. DTS Sound and an HD webcam bring work to life through rich sound and video. You're ready for web chats and conferences with Skype pre-configured on your HP ProBook. It's almost as good as being there. -
Built to perform
The power and performance of the HP ProBook is matched by the solid design and elegant finishes.Get the technology you trust from HP, with cutting-edge style that looks and feels the way you want.Tackle your workload with technology that's built strong, from the core up. This HP ProBook is made with a tough aluminum reinforced chassis for lightness and durability.Help protect sensitive electronics and key components from minor spills with a thin layer of Mylar film in the spill-resistant keyboard.HP ProBooks undergo challenging tests so you don't have to. During the HP Total Test Process, PCs experience 115,000 hours of performance trials to ensure they can withstand rigorous work environments. -
Protect your work
Stay one step ahead of hacks and attacks. Built-in security safeguards your HP ProBook against viruses, detects possible corruption, and alerts you to unauthorized changes.HP Client Security software suite helps you encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks and other security threats, and is designed to help prevent data loss and reduce downtime.Prevent data leaks. Device Access Manager with Just in Time Authentication helps prevent data from accidental or malicious transfers to USB devices without your permission.No more remembering passwords. HP Password Manager lets you quickly log in to various online accounts. Simply log on to Windows and web sites, via HP Password Manager, using the optional fingerprint reader.
- HP ProBook 470 G1 Notebook - 17.3" - Intel Core i5 4200M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
- Processor
- Intel Core i5 (4th Gen) 4200M / 2.5 GHz (3.1 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- AMD Radeon HD 8750M / Intel HD Graphics 4600
- Video Memory
- 1 GB DDR3 SDRAM
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell - up to 8.25 hours
- Security
- Fingerprint reader
- 41.38 cm x 27.95 cm x 3.15 cm
- 3 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM87 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD+ anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 1 GB DDR3 SDRAM
- Video System Features
- AMD PowerPlay Technology
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, microphone
- DTS SOUND+
Input
- Keyboard, touchpad
- Numeric Keypad
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell Lithium Ion
- Capacity
- 47 Wh
- Run Time
- Up to 8.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 90 Watt, 19 V
Connections & Expansion
- 2 x USB 3.0 , 2 x USB 2.0 , HDMI , VGA , Microphone input , Headphone output , LAN
- Memory Card Reader
- Yes (SD Card, Memory Stick, SDHC Card, SDXC Card, Memory Stick XC)
Software
- Software Included
- Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, PDF Complete Corporate Edition, HP Wireless Hotspot (free download), HP Client Security
- Case Material
- Aluminum
- Security
- HP 3D DriveGuard, HP BIOS Protection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
- Localization
- 3 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
