The sleek HP ProBook 450 with optional 10-point touchscreen and the latest generation technologies delivers powerful performance in the office or on the go. Proven reliability and comprehensive HP security features help keep your data and investment protected.
Designed for mobility
Travel in style with the updated design of the optional FHD, or HD touch, 39,6 cm (15.6") diagonal HP ProBook 450 G2 featuring a new soft touch paint finish on the LCD cover and brushed aluminum keyboard deck. -
Powerful processing
Power through projects with 5th Gen Intel Core i3/i5/i7 processors and optional discrete AMD Radeon graphics with switchable graphics support on the stunning 39,6 cm (15.6") diagonal, optional FHD or HD+ touchscreen of the HP ProBook 450. -
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP Client Security, and HP BIOSphere, as well as the embedded TPM 1.2. -
Featuring
Guard your data, device and identity with HP Client Security.HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.With TPM 1.2 your critical data has protection with hardware-based encryption keys.Rest easy with a ProBook that endures 115,000 hours of testing to help ensure reliability in the most demanding work environments.The simplicity of optional touch enriches business interaction with Windows 8.1.
- HP ProBook 450 G2 Notebook - 15.6" - Intel Core i5 - 4210U - 8 GB RAM - 750 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 750 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
- 37.5 cm x 26.28 cm x 2.55 cm
- 2.26 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4210U / 1.7 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 750 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD anti-glare
Audio & Video
- Graphics Processor
- Camera
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC3227-CG
- DTS SOUND+
Input
- Keyboard, touchpad
- Numeric Keypad
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8161GSH-CH
- Remote Management Protocol
- SNMP 2
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.3az
- Technology
- 4-cell Lithium Ion
- Capacity
- 40 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- 2 x USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Setup, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Wallpaper, HP Spare Key, HP Registration, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Disk Sanitizer, HP Ceement, HP Validity Fingerprint Driver, HP DigitalPersona Fingerprint Driver, HP UEFI System Diagnostics, HP Software Setup
- Security
- HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, HP BIOS Protection, Automatic DriveLock, HP Drive Encryption, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Intel My WiFi Technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 2.26 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
