Boost team efficiency with this high productivity, next generation wireless MFP. Print professional-quality colour at up to half the cost per page and twice the speed of colour lasers using HP PageWide Technology.
HP Officejet Pro X551dw Colour Inkjet Printer
Ideal for small to medium-size business work teams that need professional-quality, low cost per page printing at breakthrough speed, with the flexibility of wireless/mobile connectivity, touchscreen access and web-based printer management.
Print at up to twice the speed and half the cost of lasers.
- Produce quality prints with Original HP inks and save up to 50% on printing costs versus colour lasers.
- Print at up to twice the speed of lasers with the same HP PageWide Technology used in top-end digital presses.
- Certified by Guinness World Records as the world's fastest desktop printer.
- Get more done with productivity-enhancing features including new General Office mode (70 ppm) and duplex printing.
Give workgroups the power to do more with this easy-to-manage printer.
- Access print tools and tasks quickly and easily via the inituitive control panel and large colour touchscreen.
- Control settings and monitor status remotely with industry-leading management tools like HP Web Jetadmin.
- Stay productive . print up to 9,200 pages per cartridge5 and load up to 1,050 sheets at once with the optional paper tray.
- Choose HP for reliable workgroup printing . designed for high volumes of up to 4,200 pages a month
Connect, print and stay productive - at the office or on the go.
- Add this high performance printer to your wired or wireless corporate network for enhanced workgroup efficiency.
- Share the performance across workgroup members using notebooks, tablets and mobile devices . even with no network or router.
- Enjoy the flexibility of being able to print from smartphones or tablets from virtually anywhere with HP ePrint.
- Walk up and print files directly from your thumb drive using the easy-access USB port
Conserve resources without sacrificing performance.
- Control your costs . ENERGY STARR qualified device uses up to 50% less energy than colour lasers.
- Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.
- Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges.
- Reduce your impact . easily recycle your Original HP ink cartridges for free through HP Planet Partners.
Access print tools and tasks quickly and easily via the inituitive control panel and large colour touchscreen.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing. -
Get an MFP built for business performance you can rely on
In durability testing performed by Buyers Lab, over 150,000 pages were printed without jams or failure.Print from your smartphone or tablet from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray. -
Control your costs – ENERGY STAR certified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro X551dw - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 17.1 kg
- Inkjet Technology
- HP PageWide
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 70 ppm - black draft , Up to 70 ppm - colour draft , Up to 42 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 42 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Processor
- 792 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, greeting cards, labels, glossy photo paper, heavy-weight paper, cards, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss paper, satin photo paper, matte paper
- Total Media Capacity
- 550 sheets
- Media Handling
- 500-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 1000 - 4200 pages
- Networking
- Network adapter
- Printer Features
- HP EasyColor
- System Requirements
- Linux, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 51.7 cm x 39.9 cm x 41.4 cm
- Printer Type
Printer
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD, 802.11 b/g access point
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
- Printer Features
- HP EasyColor
- Media Handling
- Processor
- 792 MHz
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), Oficio (216 x 343 mm), JIS B6 (128 x 182 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 550 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m²
- Max Media Capacity
- 1050 sheets
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 75000 impressions
- 1000 - 4200 pages
- Networking
- Network adapter
- Remote Management Protocol
- SNMP 1, IPP, HTTPS
- SSL, Apple Bonjour, LEAP, TLS
- Connections
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - HP 970 , 1 x ink cartridge (cyan) - HP 971 , 1 x ink cartridge (magenta) - HP 971 , 1 x ink cartridge (yellow) - HP 971
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, cUL, GS, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, KCC, LVD, EN 62311, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 301 489-1, EN 301 489-17
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 100 Watt
- Power Consumption Stand by / Sleep
- 4.5 Watt
- Software Included
- Drivers & Utilities, Google Cloud Print, HP ePrint Wireless Direct, HP Auto Wireless Connect
- OS Required
- System Requirements Details
- Windows 7 (32/64 bits) - 1 GHz HD 2 GB , Windows Vista (32/64 bits) - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 750 MB , MacOS X 10.6/10.7/10.8 - HD 1 GB
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 15 °C
- 30 °C
- 20 - 80% (non-condensing)
- 51.7 cm
- 39.9 cm
- 41.4 cm
- 17.1 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 49.5 cm
- Height (Shipping)
- 54.3 cm
- Weight (Shipping)
- 21 kg
Ink (9)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP 970 XL High Yield Black Original Ink Cartridge | In Stock | £90.57 |
HP 971 Cyan Original Ink Cartridge | In Stock | £57.59 |
HP 971 Magenta Original Ink Cartridge | In Stock | £57.59 |
HP 971 Yellow Original Ink Cartridge | In Stock | £57.59 |
HP 971 XL High Yield Cyan Original Ink Cartridge | In Stock | £88.91 |
HP 971 XL High Yield Magenta Original Ink Cartridge | In Stock | £88.72 |
HP 971XL High Yield Yellow Original Ink Cartridge | In Stock | £88.91 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
Other bundles (2)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £158.57 |
