HP Officejet Pro X476dw Colour InkJet Multifunction Printer
Quicklinx: 8J8WWS00 Mfr#: CN461A#A80
Boost team efficiency with this high productivity, next generation wireless MFP. Print professional-quality colour at up to half the cost per page and twice the speed of colour lasers using HP PageWide Technology.
  • Give workgroups the power to do more with this easy-to-manage MFP
    Tap and swipe the large colour touchscreen to print, copy, scan, fax and send digital files.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing.
  • Get an MFP built for business performance you can rely on
    Add this high performance MFP to your wired or wireless corporate network for enhanced workgroup efficiency.Print wirelessly from PCs, tablets and smartphones and print from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray.
  • Conserve resources without sacrificing performance
    Control your costs – ENERGY STAR certified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet Pro X476dw MFP - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP PageWide - 4-ink
Monthly Duty Cycle (max)
50000 impressions
Recommended Monthly Volume
500 - 2800 pages
Max Copying Speed
Up to 36 ppm (mono) / up to 36 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, cards, labels, recycled paper, greeting cards, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, soft gloss paper, glossy paper, tri-fold paper, matte paper
Standard Media Capacity
550 sheets
Max Media Capacity
1050 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Document send function, HP Auto Wireless Connect, built-in 802.11 b/g access point
AC 110/230 V (50/60Hz)
51.7 cm x 39.9 cm x 51.7 cm
24 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
50000 impressions
500 - 2800 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
768 MB 768 MB
Max Supported Memory
768 MB 768 MB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Automatic Duplexing
Printing
Inkjet Technology
HP PageWide
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
9.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
550 sheets
Max Media Capacity
1050 sheets
50 sheets
300 sheets
Bypass tray - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 300 sheets
Speed Details
Printing: up to 55 ppm - B/W draft , Printing: up to 55 ppm - colour draft , Printing: up to 36 ppm - B/W (ISO) , Printing: up to 36 ppm - colour (ISO) , Copying: up to 55 ppm - B/W draft , Copying: up to 55 ppm - colour draft , Copying: up to 36 ppm - B/W (ISO) , Copying: up to 36 ppm - colour (ISO) , Scanning: up to 20 ppm - B/W , Scanning: up to 15 ppm - colour
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, LEAP, TLS
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Software Included
Drivers & Utilities, HP ePrint Wireless Direct
100 Watt
Power Consumption Standby
9.5 Watt
Power Consumption Sleep
4.5 Watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
51.7 cm
39.9 cm
51.7 cm
24 kg
Shipping Width
60 cm
Shipping Depth
49.5 cm
Shipping Height
65.8 cm
Shipping Weight
27.9 kg
15 °C
30 °C
20 - 80%
Ink (9)
8J8W HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
8J8W HP 970 XL High Yield Black Original Ink Cartridge In Stock £90.57
8J8W HP 971 Cyan Original Ink Cartridge In Stock £58.91
8J8W HP 971 Magenta Original Ink Cartridge In Stock £57.59
8J8W HP 971 Yellow Original Ink Cartridge In Stock £57.59
8J8W HP 971 XL High Yield Cyan Original Ink Cartridge In Stock £88.91
8J8W HP 971 XL High Yield Magenta Original Ink Cartridge In Stock £88.72
8J8W HP 971XL High Yield Yellow Original Ink Cartridge In Stock £88.91
8J8W HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
Other bundles (1)
8J8W C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
