HP OfficeJet Pro 8730 AIO Colour InkJet MFP
Quicklinx: C4P2WS00 Mfr#: D9L20A#A80
Maximise your print environment with space-saving HP Print Forward Design and professional-quality, low-cost colour. Help reduce costs with fleet management solutions. Stay productive with an all-in-one designed for high-volume enterprises.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with one-pass two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Print more and reload less. Increase paper capacity to 500 sheets with a second 250-sheet paper tray.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. Expand print capabilities with support for HP PCL 6, HP PCL 5c, and HP PS printing options.
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts. Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive. Experience a new style of business printing and imaging, with HP JetAdvantage On Demand solutions. Easily take command of your printing environment from one central location, with HP Web Jetadmin.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
  • Colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
  • Ethernet (printer)
    Add this device to your office Ethernet network to share with your workgroup.
  • Scan to email
    Save time by sending scanned documents or photos directly from your printer to email recipients.
HP Officejet Pro 8730 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
200 - 2000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, fax to e-mail
AC 120/230 V (50/60Hz)
50 cm x 53.1 cm x 32.8 cm
15.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
200 - 2000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Colour Management Features
sRGB, Adobe RGB
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
180 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 215.9 x 279.4 mm
250 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 50 sheets - 216 x 356 mm , 2 x input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 180 g/m² , Output tray - 150 sheets
Speed Details
Scanning: up to 19 ipm - B/W , Scanning: up to 8 ipm - colour , Scanning: up to 23 ipm - B/W duplex , Scanning: up to 12 ipm - colour duplex , Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 36 ppm (A4) - B/W draft , Printing: up to 36 ppm (A4) - colour draft , Printing: up to 36 ppm (Letter A) - B/W draft , Printing: up to 36 ppm (Letter A) - colour draft , Copying: up to 22 ppm - B/W (ISO) , Copying: up to 16 ppm - colour (ISO) , Copying: up to 36 ppm (A4) - B/W draft , Copying: up to 36 ppm (A4) - colour draft , Copying: up to 36 ppm (Letter A) - B/W draft , Copying: up to 36 ppm (Letter A) - colour draft
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Participation Study
35 Watt
Power Consumption Standby
7.2 Watt
Power Consumption Sleep
1.3 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 800 pages - HP 952 , 1 x ink cartridge (cyan) - up to 490 pages - HP 952 , 1 x ink cartridge (magenta) - up to 490 pages - HP 952 , 1 x ink cartridge (yellow) - up to 490 pages - HP 952
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
50 cm
53.1 cm
32.8 cm
15.2 kg
Shipping Width
61.2 cm
Shipping Depth
58.3 cm
Shipping Height
39.3 cm
Shipping Weight
18.7 kg
Sound Emission
59 dBA (operating)
15 °C
32 °C
20 - 80%
Ink (12)
C4P2 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
C4P2 HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £4.92
C4P2 HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.43
C4P2 HP 81A Black Original LaserJet Toner Cartridge In Stock £150.94
C4P2 HP 81X High Yield Black Original LaserJet Toner Cartridge In Stock £249.76
C4P2 HP 953XL High Yield Black Original Ink cartridge for Officejet In Stock £42.26
C4P2 HP 953XL High Yield Cyan Original Ink cartridge for Officejet In Stock £29.83
C4P2 HP 953XL High Yield Magenta Original Ink cartridge for Officeje In Stock £29.90
C4P2 HP 953XL High Yield Yellow Original Ink cartridge for Officejet In Stock £29.90
C4P2 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
C4P2 HP 953 CMYK Original INK Cartridge 4 In Stock £78.12
Other bundles (1)
C4P2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
