Stay productive and tackle high-volume jobs with print, fax, scan, and copy versatility. Save up to 70% on ink with HP Instant Ink.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Remarkable value for professional, in-office colour
Count on remarkable value for your colour printing needs. Spend up to 50% less per page compared with lasers, and produce the colour and black text output you need to keep your business humming.
Everything you need to finish jobs fast
Finish jobs in a snap with an all-in-one designed for fast, high-volume performance for the office. Quick two-sided prints and swift fax, scan, and copy speeds keep workgroups productive. Manage tasks easily with touchscreen digital shortcuts.
Mobile printing that keeps your business covered
Keep business moving from anywhere in the office. Easily print when and where you need to from your smartphone, tablet, or notebook PC – and maintain privacy.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup. -
Print, scan, copy, and fax with ADF
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP Officejet Pro 8710 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, fax to e-mail
- Power
- AC 120/230 V (50/60Hz)
- 49.95 cm x 53.01 cm x 33.91 cm
- 11.54 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 3, PCL 3e, PDF, PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 180 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), 215.9 x 279.4 mm
- 250 sheets
- 250 sheets
- 150 sheets
- ADF - 50 sheets , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 180 g/m² , Output tray - 150 sheets
- Speed Details
- Scanning: up to 17 ipm - B/W , Scanning: up to 8 ipm - colour , Scanning: up to 17 ipm - B/W duplex , Scanning: up to 8 ipm - colour duplex , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 18 ppm - colour (ISO) , Printing: up to 35 ppm (Letter A) - B/W draft , Printing: up to 35 ppm (Letter A) - colour draft , Copying: up to 30 ppm (Letter A) - B/W draft , Copying: up to 27 ppm (Letter A) - colour draft , Copying: up to 20 ppm - B/W (ISO) , Copying: up to 14 ppm - colour (ISO) , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 27 ppm (A4) - colour draft , Printing: up to 35 ppm (A4) - B/W draft , Printing: up to 35 ppm (A4) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Participation Study
- Voltage Required
- 35 Watt
- Power Consumption Standby
- 6.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 800 pages - HP 953 , 1 x ink cartridge (cyan) - up to 490 pages - HP 953 , 1 x ink cartridge (magenta) - up to 490 pages - HP 953 , 1 x ink cartridge (yellow) - up to 490 pages - HP 953
- ENERGY STAR Certified
- 49.95 cm
- 53.01 cm
- 33.91 cm
- 11.54 kg
- Shipping Weight
- 14.5 kg
- Sound Emission
- 63 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.68 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.69 |
