HP Officejet 7612 eAIO A3 Wide Format Printer
Quicklinx: 9MWRWS00 Mfr#: G1X85A#A80
Do more with this affordable, reliable HP e-All-in-One. Create professional-quality marketing materials from postcard size to A3+. Scan, copy and fax too, and maximise productivity with wireless networking and easy mobile printing.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
  • Borderless printing
    Borderless photos are printed right to the edge of the paper. You get beautiful photo prints with no trimming!
HP Officejet 7612 Wide Format e-All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
12000 pages
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 9 ppm (mono) / up to 6 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Speed
Up to 15 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.65"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - 330.2 x 1117.6 mm (max)
Media Type
Plain paper, greeting cards, photo paper, thick paper, card stock, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Save to memory card, print from USB flash drive, scan to e-mail, scan to folder
AC 120/230 V (50/60Hz)
61.7 cm x 50.51 cm x 29.7 cm
17.6 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
12000 pages
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
110 station(s)
Broadcast Transmission
48 stations
Delayed Transmission
Yes (black only)
Fax forwarding, colour faxing, junk fax barrier, group dialling, auto reduction, Distinctive Ring Detection (DRD), delayed sending, poll receive
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Other
Min Media Weight
34 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 330 x 1118 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, Tabloid (279 x 432 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm), Japanese postcard (100 x 148 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
75 sheets
Input tray - 250 sheets size: 76.2 x 127 mm - 330.2 x 1117.6 mm weight: 34 g/m² - 250 g/m² , ADF - 35 sheets - Legal (216 x 356 mm) , Output tray - 75 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W draft , Printing: up to 28 ppm (A4) - colour draft , Printing: up to 15 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 28 ppm (A4) - colour draft , Copying: up to 9 ppm - B/W (ISO) , Copying: up to 6 ppm - colour (ISO) , Printing: 17 sec (10 x 15 cm (4"x6")) - photo draft , Printing: 50 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 33 ppm (Letter A) - B/W draft
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Operating System Support
Linux, Apple Mac OS X 10.6, Apple Mac OS X 10.8, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
Software Included
Drivers & Utilities
27.7 Watt
Power Consumption Standby
4.57 Watt
Power Consumption Sleep
1.89 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 400 pages - HP 932 , 1 x ink cartridge (cyan) - up to 330 pages - HP 933 , 1 x ink cartridge (magenta) - up to 330 pages - HP 933 , 1 x ink cartridge (yellow) - up to 330 pages - HP 933
BSMI, GOST, EN 61000-3-2, EN55022, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, CCC, EMC, CS-03, FCC CFR47 Part 68, R&TTE, RoHS, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, WEEE, ANATEL, TBR21, EN 60825-1, GB 4943, AS/NZS 60950, CEL, AS/ACIF S002, TIA/EIA-968-A, NOM-019-SCFI-1998
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
61.7 cm
50.51 cm
29.7 cm
17.6 kg
Shipping Width
70 cm
Shipping Depth
50 cm
Shipping Height
61 cm
Shipping Weight
22.9 kg
Sound Emission
55 dBA (operating)
5 °C
10 - 80%
Ink (2)
9MWR HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.68
9MWR HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.69
Other bundles (1)
9MWR C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
