Manage home office projects quickly and easily with this powerful wireless e-all-in-one. Print lab-quality photos and professional, two-sided documents at home or from a mobile device, and scan, copy or fax multipage documents hands-free.
Print, scan, copy and fax with this high productivity e-all-in-one with built-in ADF
Leave stacks of papers to fax, scan or copy using the built-in 35-sheet automatic document feeder.Get professional-looking results – print borderless, lab-quality photos and crisp, laser-sharp documents.Save time and paper with automatic two-sided printing and copying.
- HP Officejet 4630 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 150 - 600 pages
- Max Copying Speed
- Up to 6 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 8.8 ppm (mono) / up to 5.2 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 100 sheets
- Max Media Capacity
- 100 sheets
- Output Trays Capacity
- 30 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, automatic paper sensor
- Power
- AC 120/230 V (50/60Hz)
- 44.5 cm x 33.1 cm x 18.8 cm
- 6.22 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 1000 pages
- 150 - 600 pages
- Display Diagonal Size
- 2"
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 64 MB
- Max Supported Memory
- 64 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 20
- Copying Features
- Fit to page, ID Card Copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 19 sec
- First Print Out Time Colour
- 24 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Total Memory Capacity
- Up to 99 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 76 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International B5 (176 x 250 mm), A4 (210 x 297 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- 100 sheets
- 100 sheets
- 30 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 30 sheets - Legal (216 x 356 mm) , ADF - 35 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 8.8 ppm - B/W (ISO) , Printing: up to 5.2 ppm - colour (ISO) , Printing: up to 21 ppm (Letter A) - B/W draft , Printing: up to 17 ppm (Letter A) - colour draft , Copying: up to 6 ppm - B/W , Copying: up to 4 ppm - colour , Printing: up to 21 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
- Software Included
- Drivers & Utilities, HP Photo Creations
- Voltage Required
- 15 Watt
- Power Consumption Standby
- 3.2 Watt
- Power Consumption Sleep
- 0.7 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 61 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 61
- EN 61000-3-2, EN55022, EN 61000-3-3, CISPR 22, FCC CFR47 Part 15, EN 62311, EN55024:1998 + A1 + A2, IEC 62479, EN 62479:2010, IEC/EN60950-1:2006 +A11:2009 +A1:2010, IEC 62311, IEC 60950-1:2005 (ed.2)+A1:2009
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - phone consulting - 1 year
- 44.5 cm
- 33.1 cm
- 18.8 cm
- 6.22 kg
- Shipping Width
- 49.1 cm
- Shipping Depth
- 39.3 cm
- Shipping Height
- 22.5 cm
- Shipping Weight
- 7.56 kg
- Sound Emission
- 49.1 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.74 |
HP 301XL High Yield Tri-colour Original Ink Cartridge | In Stock | £30.97 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.74 |
