Produce professional-quality documents on the go, using built-in Bluetooth wireless technology. Print from a variety of selected notebooks and smartphones.
Impressive features bundled in one mobile product.
Print at your convenience while on the go, using built-in Bluetooth® wireless technology.[1]
Rely on a long-life, lithium ion battery--print up to 500 pages when the battery is fully charged.
Do more--produce professional-quality documents on the go, using Original HP high-capacity ink cartridges.
Print at up to 22 ppm black/18 ppm color and ISO (laser-comparable) speeds up to 5 ppm black/3.5 ppm color.[4]
Professional-quality documents from mobile devices.[1]
Use Bluetooth® technology to produce professional-quality documents from selected notebooks or netbooks.[1]
Print high-quality documents from selected smartphones and mobile phones, using Bluetooth® technology.[1]
Print directly from Windows Mobile® phones and BlackBerry, Palm OS® and Android smartphones.[1]
Reliable mobile printing made easy.
Expect great performance--this printer is tested to operate in tough conditions.
Stay productive on the go with a 500-page monthly duty-cycle and a 50-sheet paper tray.
Monitor battery life with an indicator light and disconnect quickly with the Bluetooth® On/Off button.
Power your printer without the hassle of multiple adapters.
High-quality documents from a compact printer.
Take advantage of convenient mobile printing from a reliable, compact printer.[1]
Print documents with laser-quality black text and vivid color graphics.[5]
Produce lab-quality, borderless 4 x 6-inch photos on the go.[1][6]
Connect to a PictBridge compatible device and print lab-quality photos on the go.[1]
Footnotes:
[1]Notebook or netbook must be Bluetooth enabled. Includes Windows Mobile® phones. Additional fee required through 3rd party service provider for BlackBerry, Palm OS® and Android smartphones.
[3]High-capacity cartridges and ColorLok® paper not included. Please purchase separately.
[4]After first page or after first set of ISO test pages. For more information, see http://www.hp.com/go/printerclaims.
[5]Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[6]On photo paper only.
Get performance you can rely on – designed for easy and reliable mobile printing
Enjoy easy, reliable printing – intuitive control panel and rugged, drop-tested design for tough conditions.Monitor battery life via front panel indicator light and disconnect quickly with the Bluetooth on/off button.Charge and power using included HP 65W Smart AC Adapter – works with your HP notebook too so no need for multiple adapters.Leave multi-page documents to print – load up to 50 sheets into the built-in paper tray.
- HP Officejet 100 Mobile Printer - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- Form Factor
- Portable
- 2.5 kg
- Localisation
- English / United Kingdom
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Media Size Class
- Legal
- Max Media Size
- Legal (216 x 356 mm)
- Min Media Size (Custom)
- 76 mm x 102 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 22 ppm - black draft - A4 (210 x 297 mm) , Up to 18 ppm - colour draft - A4 (210 x 297 mm) , Up to 5 ppm - black laser quality , Up to 3.5 ppm - colour laser quality
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB, Bluetooth, USB host
- Processor
- 220 MHz
- RAM Installed (Max)
- 64 MB
- Language Simulation
- PCL 3
- Media Type
- Envelopes, greeting cards, labels, plain paper, photo paper, index cards
- Total Media Capacity
- 50 sheets
- Monthly Duty Cycle (max)
- 500 pages
- Networking
- Print server - Bluetooth 2.0 EDR
- Battery
- Lithium Ion Included Qty 1
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows XP Professional SP2, Microsoft Windows Mobile 5.0, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Mobile 6.x
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 34.8 cm x 17.5 cm x 8.4 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 600 dpi
- 4800 x 1200 dpi
- Direct Printing Specifications
- PictBridge
- PCL 3
- Fonts Included
- 8 x scalable
- Processor
- 220 MHz
RAM
- 64 MB
Media Handling
- Media Path Type
- Straight
- Media Type
- Media Size Class
- Legal
- Max Media Size
- 76 mm x 102 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 102 mm
- Borderless Photo Sizes
- 100 x 150 mm
- Envelope Sizes
- International DL (110 x 220 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 50 sheets
- Media Feeders
- 1 x automatic - 50 sheets weight: 60 g/m² - 200 g/m²
Duty Cycle
- 500 pages
- Networking
- Print server
- Data Link Protocol
- Bluetooth 2.0 EDR
- Bluetooth 2.0
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x ink cartridge (black) - HP 337 , 1 x ink cartridge (yellow/cyan/magenta) - HP 343
- Power Device
- Power adapter
- Frequency Required
- 50/60 Hz
- 15 Watt
- Power Consumption Stand by / Sleep
- 5.8 Watt
- Lithium Ion
- Included
- 1
- Run Time (Up To)
- 3 hour(s)
- Software Included
- Bing Toolbar, HP SureSupply
- OS Required
- System Requirements Details
- Windows 7 - 1 GHz - RAM 1 GB - HD 1 GB , Windows 7 64-bit Edition - 1 GHz - RAM 2 GB - HD 1 GB , Windows Vista - 800 MHz - RAM 512 MB - HD 900 MB , Windows XP SP2 - Pentium II - 233 MHz - RAM 512 MB - HD 500 MB , MacOS X 10.5 or later - PowerPC G4 HD 300 MB
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 0 °C
- 55 °C
- 15 - 95%
- Sound Emission (Operating)
- 58 dBA
- 34.8 cm
- 17.5 cm
- 8.4 cm
- 2.5 kg
- Weight (Shipping)
- 4.5 kg
HP 344 Tri-colour Original Ink Cartridge | In Stock | £52.64 |
HP 343 Tri-colour Original Ink Cartridge | In Stock | £39.19 |
