The HP NC373T is a high performance PCI Express Gigabit Ethernet multifunction network adapter for either standard or low profile (half height) slots in ProLiant servers running in a twisted pair (copper) network environment. In addition to delivering standard Gigabit Ethernet networking, the NC373T supports TOE (TCP/IP Offload Engine) for Windows only, Internet Small Computer System Interface (iSCSI), and RDMA (Remote Direct Memory Access) over a single network connection making it a multifunction Ethernet server adapter. Besides its multifunction capabilities, the NC373T ships with all the advanced server features that ProLiant customers have come to expect, such as support for failover and load balancing, Pre-Boot Execution Environment (PXE), large send offload capability, multiple VLAN tagging, and auto-negotiated 10/100/1000Mbps Ethernet speeds.
Gigabit Ethernet throughput
A 10/100/1000 Mbps Ethernet transfer rate delivers outstanding network performance that improves response time and removes bottlenecks across the entire network. -
TCP/IP Offloading
TCP/IP Offload Engine (TOE) moves the processing of data in the TCP protocol stack from the server CPU to the network card, freeing CPU cycles for other duties. The HP NC373T PCI Express Multifunction Gigabit Server Adapter supports TOE when Windows TOE Chimney (a part of the Scalable Networking Pack available directly from Microsoft) is installed. With TOE, network communications are improved and server efficiency is increased. -
Accelerated iSCSI
Accelerated iSCSI enables the HP NC373T PCI Express Multifunction Gigabit Server Adapter to multi-function as both as a network adapter and as a storage host bus adapter (HBA), thereby providing access to storage platforms and to servers over a single connection. Additionally, the HP NC373T PCI Express Multifunction Gigabit Server Adapter offloads the iSCSI software to the hardware for improved performance. -
Load Balancing
Transmit Load Balancing (TLB) and Switch-Assisted Load Balancing (SLB) are two advanced features that customers can use to build a bigger pipe for improved networking bandwidth. These port-bonding techniques enable users to install up to eight adapters ports in an HP ProLiant Server, aggregating their throughput up to a theoretical maximum of 16 Gigabits per second full-duplex transmissions. The HP NC373T PCI Express Multifunction Gigabit Server Adapter can be configured with other NC-series Ethernet server adapter teams supported on HP ProLiant Servers. -
HP ProLiant Essentials Remote Direct Memory Access (RDMA) pack for multifunction Gigabit server adapter
The HP ProLiant Essentials RDMA Pack enables RDMA on an HP Multifunction Server Adapter. RDMA is a communications protocol that provides direct transmission of data from the memory of one computer to the memory of another computer with minimal demands on the host CPU. RDMA provides a high-speed, high-performance connection between servers on the same network. RDMA Pack licenses are port-based; the licensed seats are available to individual ports on the multi-function server adapter. -
Checksum and segmentation offloads, and interrupt coalescing
When running as a standard Gigabit adapter, the HP NC373T PCI Express Multifunction Gigabit Server Adapter features TCP Checksum Offloads, as well as TCP Segmentation Offloads and Interrupt Coalescence. These features reduce the load on the CPU for overall improved system response. Interrupt Coalescence is a feature that groups multiple packets and issues a single interrupt to the host. This process improves host efficiency. -
Network Fault Tolerance (NFT)
Network Fault Tolerance, sometimes called "failover" or "NIC Redundancy, " enables the installation of multiple HP NC373T PCI Express Multifunction Gigabit Server Adapters or other network adapters so that the active device can be backed up by a redundant adapter to improve availability. The HP Teaming utility also enables users to specify that when a failed adapter is fixed and replaced, the original adapter resumes its function as the primary network connection. -
Management support
Similar to all HP ProLiant server adapters, the HP NC373T PCI Express Multifunction Gigabit Server Adapter ships with drivers and agents that can be managed from all versions of the HP Systems Insight Manager (HP SIM). Additionally, it supports any management application that support SNMP. -
Server integration
HP SIM can recognize the HP NC373T PCI Express Multifunction Gigabit Server Adapter individually or in port-bonded teams, and HP SIM can collect and report SNMP statistics on the adapter events. Integrated Management Log (IML) support is provided by the HP NC373T PCI Express Multifunction Gigabit Server Adapter for critical event logging on HP Servers. -
Configuration utilities
Each HP NC373T PCI Express Multifunction Gigabit Server Adapter ships with a set of utilities that enable the user to: Enable initial diagnostics within Microsoft Windows, Linux, and DOS operating systems. Configure network adapter teaming in a Microsoft Windows environment. The Windows adapter teaming configuration utility includes a patented teaming GUI for the Microsoft Windows 2000 and 2003 Operating Systems. Support for scripted installations of teams in a Microsoft Windows environment allow for unattended operating system installations. -
LED indicators
Bracket LED indicators show link integrity, network activity, and network speed for easy troubleshooting.
- HPE NC373T - network adapter - PCIe x4 - Gigabit Ethernet
- Network adapter
- Interface (Bus) Type
- PCI Express x4
- PCI Specification Revision
- PCI-X 1.0a
- Ports
- Gigabit Ethernet
- 16.8 cm x 6.4 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- TCP/IP, iSCSI
- Processor
- 1 x Broadcom BCM5708
- RAM
- 92 KB
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3p
- System Requirements
- Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Standard Edition, Red Hat Enterprise Linux 3, SuSE Linux Enterprise Server 9 for x86/AMD64/Intel EM64T, Microsoft Windows Server 2003 Standard x64 Edition, Red Hat Enterprise Linux 4, Microsoft Windows Server 2003 Enterprise x64 Edition
- Designed For
- ProLiant DL120 G7, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G7, ML110 G7, ML370 G6, SL160s G6, SL165s G7, SL165z G7; StorageWorks Network Storage Gateway X3800 G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
- Network adapter
- PCI Express x4
- PCI-X 1.0a
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP, iSCSI
- Remote Management Protocol
- SNMP
- Flow control, NFT, TLB, TCP/IP offloading
Processor / Memory
- Processor
- RAM
- 92 KB
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- PCI Express x4
- Included Accessories
- Low-profile bracket
- FCC Class B certified, CSA, VCCI, EN55022, ICES-003, EN55024, UL 60950, CISPR 22, EMC, MIC, AS/NZS 3548, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
- Software Included
- Drivers & Utilities
- OS Required
- 16.8 cm
- 6.4 cm
- 0 °C
- 55 °C
- 10 - 90%
- Designed For
- HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL320 G4 SAS VPN Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G6 ICE Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server, SL160s G6, SL160z G6, SL165s G7, SL165z G7, SL170z G6, SL2x170z G6 , HPE StorageWorks All-in-One Storage System 1200r 12TB SATA Model, 1200r 2.4TB SAS Model, 1200r 3.6TB SAS Model, 1200r 5.4TB SAS Model, 1200r 6TB SATA Model, 1200r 9TB SATA Model , HPE StorageWorks Network Storage Gateway X3800 G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
