Fast wake-up and print
Print the first page from sleep mode as fast as 8.0 seconds. -
Fast two-sided printing
Print two-sided documents as fast as 32 ipm (images per minute). -
Optional high-yield cartridge
Optional 9K high-yield Original HP Toner cartridge with JetIntelligence. -
Compact size
Compact design lets this printer fit into small spaces. -
Optional job storage
Add a USB drive for built-in job storage and retrieval. -
Low energy use
This printer is optimised for low energy consumption.
- HP LaserJet Pro M402dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 8.58 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 38 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 40 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 30 ipm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 32 ipm - B/W duplex (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 4800 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- AirPrint Enabled
- Processor
- 1200 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.7, PCLm, URF, PWG
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology
- System Requirements
- UNIX, Linux, Red Hat Linux 8.0, Slackware Linux 9.1, Microsoft Windows Vista (32-bit versions), Red Hat Enterprise Linux 5, Microsoft Windows XP SP3, Linux Linpus 9.4, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Mandriva Linux 2010, Linux Linpus 9.5, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Linux 9.0, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Debian Linux 6.0.7, Apple OS X 10.9 Mavericks, Red Hat Fedora 18, Mandriva Linux 2011, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Debian Linux 6.0.5, Ubuntu 14.04, Red Hat Fedora 19, Debian Linux 6.0, Red Hat Enterprise Linux 7, Linux Mint 14, Linux Mint 15, Debian Linux 7.4, Apple MacOS X 10.10, Debian Linux 7.0, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.1 or later, Debian Linux 7.1 or later, PCLinuxOS 2006 or later, Slackware Linux 9.0 or later, gOS
- Microsoft Certification
- Compatible with Windows 7
- 38.1 cm x 35.7 cm x 21.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 600 dpi
- PostScript Support
- Standard
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1200 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm, 104.9 x 148.59 mm
- Media Weight
- 60 g/m² - 175 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP
- SSL, Apple Bonjour, TLS, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 3100 pages - HP 26A
- FCC Class B certified, ICES-003, Laser Class 1, FCC CFR47 Part 15, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, GB 4943-2011, GB 17625.1-2012, EN 55024:2010, CISPR 22:2008, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2013, IEC 60950-1:2005 + A1:2009, EN 55022:2010 Class B
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 591 Watt
- Power Consumption Stand by
- 6.1 Watt
- Power Consumption Sleep
- 2.8 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 15 °C
- 32.5 °C
- 30 - 70% (non-condensing)
- Sound Emission (Operating)
- 54 dBA
- 38.1 cm
- 35.7 cm
- 21.6 cm
- 8.58 kg
- Width (Shipping)
- 44.3 cm
- Depth (Shipping)
- 27.4 cm
- Height (Shipping)
- 46.4 cm
- Weight (Shipping)
- 11.36 kg
HP 26A Black Original Laserjet Toner | In Stock | £101.52 |
HP 26X High Yield Black Original LaserJet Toner Cartridge | In Stock | £173.96 |
