Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
Get it all done – with a wireless MFP that’s easy on your budget. Use the 3-inch colour touchscreen and simply tap to print, copy, scan and fax professional-quality documents.
Easily manage your MFP from the 7.6 cm (3-inch) colour touchscreen. Use the simple, intuitive control panel to set up projects easily and start printing right away. Finish projects fast – print documents at up to 20 ppm and get a first page out in as fast as 9.5 seconds with Instant-On Technology. Use the 35-page automatic document feeder to make the most of your time. Easily copy both sides of a two-sided ID or other small document onto the front of a single-page. Keep up with the pace of business with an MFP that prints, copies, faxes and scans.
Get right to printing, right away.
Spend less time at your MFP and more with your customers. Print, copy, and scan at high speeds that keep up with the pace of business. Help save energy with HP Instant-on Technology and HP Auto-On/Auto-Off Technology.
Enable easy printing from smartphones, tablets and laptops, at work, home or on the go.
Extend your printing reach. Easily set up, print, and share using Ethernet and wireless connectivity. Connect to your wireless printer in a snap using wireless direct printing. Print from your mobile device with built-in print capability or HP ePrint app and software. Print from virtually anywhere with AirPrint™.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Unleash your printing
Print wirelessly from your mobile device without a Wi-Fi code or password. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP LaserJet Pro MFP M127fw - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3.5"
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Embedded web browser
- Power
- AC 230 V (50/60Hz)
- 42 cm x 36.5 cm x 30.9 cm
- 9.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 pages
- 250 - 2000 pages
- Display Diagonal Size
- 3.5"
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- PCL
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Transmission Memory Capacity
- Up to 500 pages
- Fax Printing Speed
- Up to 20 ppm
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
- Max Original Size
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 100 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 21 ppm (Letter A) - B/W normal , Scanning: up to 7 ppm - B/W normal , Scanning: up to 5 ppm - colour normal , Copying: up to 21 ppm (Letter A) - B/W normal , Printing: up to 20 ppm (A4) - B/W normal , Copying: up to 20 ppm (A4) - B/W normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
- Software Included
- Drivers & Utilities
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 4.5 Watt
- Power Consumption Sleep
- 1.1 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, FCC Part 15.247, Directive 1999/5/EC, RSS-210, FCC Part 68, EMC, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, GB 17625.1-2003 EMC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, EN 60950-1:2006, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 301 489-1, EN 301 489-17
- ENERGY STAR Certified
- Limited warranty - 1 year
- 42 cm
- 36.5 cm
- 30.9 cm
- 9.1 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 11.5 kg
- Sound Emission
- 52 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 83A Black Original LaserJet Toner Cartridge | In Stock | £56.07 |
