HP LaserJet Pro 400 M425dn Mono All-in-One Printer
This networked MFP boosts productivity. Share resources with wireless networking[1],[2], and print from virtually anywhere with HP ePrint[3]. Improve workflow with access to business apps. Save time with automatic two-sided scanning and copying.
Ideal for business users who need a versatile, networked HP LaserJet MFP for everyday office functions, including fax, copy, scan to email and to network folders, touchscreen access to business apps and the ability to print from mobile devices.
Increase productivity - even on the go.
-Scan documents directly to email or a network folder. Save time and get fast results: the dual head scanner means two-sided pages are only scanned once.
-Print at up to 33 ppm A4, and get a first page in as fast as eight seconds.
-Print from virtually anywhere with HP ePrint[3]. Send files from a smartphone directly to your printer using HP wireless direct printing[1],[2].
-Set up and share anywhere in the office with wireless connectivity[2],[4]. Configure networking fast[2],[5].
Produce high-quality documents time after time.
-Print professional-quality documents with bold text and sharp images, using Original HP LaserJet toner cartridges.
-Improve performance with trusted HP reliability. Do more with 800-sheets maximum paper input capacity (with optional 500-sheet tray).
-Save time with Original HP LaserJet toner cartridges that are reliable and feature an all-in-one design for easy installation.
-Print more affordably using an optional high-capacity Original HP LaserJet black toner cartridge[6].
Easily manage print jobs and access business apps.
-Use business apps and an 8.89 cm (3.5-inch) colour touchscreen to access and print from the web or scan to online storage sites[7].
-Plug and print in as fast as five minutes - there's no CD required with HP Smart Install[8].
-Manage workflow with intuitive features right on the printer: use the easy-access USB port to print from - and save scans to - a flash drive.
-Easily control your print environment and save IT time and costs - HP Web Jetadmin helps you monitor equipment and increase uptime.
Reduce your environmental impact.
-Reduce paper use by up to 50% with automatic two-sided printing.
-Save energy with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't[9].
-Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners[10].
-This MFP's compact size is designed to use less space and create less packaging waste.
[1] Not available on all printers. Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at www.hp.com/go/eprintcenter.
[2] HP wireless direct printing, HP Auto Wireless Connect, and built-in wireless connectivity are only available on the HP LaserJet Pro 400 MFP M425dw.
[3] Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Requires HP Web Services Account Registration. Print times may vary. For a list of supported documents, and image types, see www.hp.com/go/eprintcenter. And for additional solutions, see www.hp.com/go/mobile-printing-solutions.
[4] Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[5] HP Auto Wireless Connect may not be available for all system configurations. Wireless performance is dependent upon physical environment and distance from access point. For information on compatibility, visit www.hp.com/go/autowirelessconnect.
[6] HP 80X LaserJet Black Toner Cartridge not included; must be purchased separately.
[7] Requires a wireless access point and an Internet connection to the printer. Services may require registration. Availability varies by country, language, and agreements, and requires a firmware upgrade. For details, www.hp.com/go/eprintcenter.
[8] HP Smart Install works with Windows only.
[9] HP Auto-On/Auto-Off Technology capabilities subject to printer and settings.
[10] Programme availability varies. HP cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle.
HP 80A Black Original LaserJet Toner Cartridge | In Stock | £90.52 |
HP 80X High Yield Black Original LaserJet Toner Cartridge | In Stock | £155.84 |
HP 80X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £280.52 |
