Do more with your workday. Set up anywhere in the office using built-in wireless networking and share printing resources on a network. Print on the go with mobile printing options. Use business apps to access and print from the web.
Stay productive and boost business with wireless networking and impressive mobility
Set up and share anywhere in the office with wireless connectivity,. Configure networking fast,.Print from virtually anywhere with HP ePrint,. Print wirelessly from your iPad , iPhone , and iPod touch with AirPrint .Send files from a mobile device directly to your printer using HP wireless direct printing,. -
Experience web-connected ease of use
Use business apps and the 8.89 cm (3.5-inch) colour touchscreen to access and print from the web,, e.g. with Google Docs 2012 Google.Manage workflow with intuitive features right on the printer. A convenient USB port enables printing directly from a flash drive.Easily control your print environment and save IT time and costs – HP Web Jetadmin helps you monitor equipment and increase uptime. -
Enjoy professional-quality output for a great value
Produce professional-quality business documents with bold, crisp text and sharp images.Get peace of mind with trusted HP LaserJet reliability and consistent print quality from the first to the last page.Save time with easy-to-install Original HP cartridges, and save money with optional high-capacity cartridges designed for frequent printing.Do more with a 300-sheet paper capacity (800-sheets total with optional 500-sheet tray). -
Reduce your environmental impact
Save energy with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't.Reduce paper use by up to 50% with automatic two-sided printing.Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.Reduce packaging waste: Original HP toner cartridge HP 80A ships in the printer.
- HP LaserJet Pro 400 M401d - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 10.7 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 33 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - black normal - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0
- Processor
- 800 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, card stock, light-weight paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 3000 pages
- System Requirements
- HP-UX 11i, Microsoft Windows XP SP2 or later, Apple MacOS X 10.6, Debian GNU/Linux 5.0, Red Hat Enterprise Linux 5, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, Linux Linpus 9.4, Microsoft Windows Vista (32/64 bits), openSUSE 11.3, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Red Hat Fedora 14, Apple MacOS X Lion 10.7, Red Hat Fedora 15, Ubuntu 10.10, openSUSE 11.4, Ubuntu 11.04, Linux Linpus 9.5, Debian GNU/Linux 6.0
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 36.46 cm x 36.8 cm x 26.75 cm
- Printer Type
- Personal printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 84 x TrueType
- Media Handling
- Processor
- 800 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76 x 127 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 750 - 3000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 2700 pages - HP 80A
- FCC Class B certified, ICES-003, EN55024, CISPR 22, EN55022 Class B, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, IEC 60825-1, EN 60825-1, GB 4943, GB 17625.1, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 570 Watt
- Power Consumption Stand by / Sleep
- 6.2 Watt
- 7.3 Watt
- Power Consumption Sleep
- 6.2 Watt
- OS Required
- System Requirements Details
- Windows 7/Vista - 1 GHz - RAM 1 GB - HD 400 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.5/10.6/10.7 - PowerPC G4 HD 500 MB , Windows Vista 64-bit Edition - 1 GHz - RAM 2 GB - HD 400 GB , Windows 7 64-bit Edition - 1 GHz - RAM 2 GB - HD 400 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 30 - 70%
- Sound Emission (Operating)
- 51 dBA
- 36.46 cm
- 36.8 cm
- 26.75 cm
- 10.7 kg
- Width (Shipping)
- 43 cm
- Depth (Shipping)
- 33 cm
- Height (Shipping)
- 48 cm
- Weight (Shipping)
- 13.9 kg
HP 80A Black Original LaserJet Toner Cartridge | In Stock | £90.71 |
HP 80X High Yield Black Original LaserJet Toner Cartridge | In Stock | £156.18 |
HP 80X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £281.12 |
