HP LaserJet Pro 400 color MFP M475dw - ( fax / copier / printer / scanner ) - colour
Quicklinx: 7XSJWS00 Mfr#: CE864A#B19
Print professional-looking two-sided color documents in-house with HP LaserJet Pro 400 Color MFP M475dw. Easily print, scan to e-mail, copy, and fax with this Web-connected model. And you can print from virtually anywhere using HP ePrint, Apple AirPrint, and wireless direct print.
Print, copy, scan and fax with one efficient, networked HP LaserJet MFP.
Reduce waste and easily manage paper use with automatic two-sided printing.
Boost productivity and save time with impressive print speeds up to 20 ppm A4.
Conveniently locate the MFP anywhere in the office, using wireless connectivity[2]. Use built-in 10/100 Ethernet to share printing on a network and use the front-facing USB port to print from - and save scans to - a flash drive.
Install the MFP in only a few minutes and quickly start printing: there's no CD required with HP Smart Install[3].
Experience web-connected efficiency and expandability.
Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access, store and print information from the web[4].
Convert hard copies to digital files quickly and easily - scan to a USB drive, email or network folder[5].
Print from virtually anywhere with HP ePrint[1]. Print from smartphones directly to your printer using ePrint Wireless Direct printing[6] and print wirelessly from your iPad®, iPhone®, and iPod touch® with AirPrint™[7].
Proactively manage this MFP with HP Web Jetadmin.
Make an impression with professional colour marketing materials created in-house.
Achieve crisp, detailed text and consistently smooth colour with HP ImageREt 3600 and Original HP LaserJet toner cartridges.
Design and produce colour marketing materials in-house on a range of media sizes from 8.9 x 12.7 cm (3.5 x 5 inches) to 21.6 x 35.6 cm (8.5 x 14 inches). Go to www.hp.com/create for tips and templates from HP.
Print black text affordably - at the same cost per page as a black-and-white HP LaserJet MFP[8].
Save money with high-capacity black print cartridges designed for frequent printing[9].
Conserve resources with innovative energy-saving features.
Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't[10]. Save even more energy with Instant-on Technology[11].
Manage paper usage and get up to 50% paper savings, using automatic two-sided printing.
Get centralised, easy access to custom, energy-saving options and printer settings with HP EcoSMART Console.
Take advantage of free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[12].
[1] Requires an Internet connection to the printer. Feature works with any Internet- and email-capable device. Print times may vary. For a list of supported documents and image types, see www.hp.com/go/eprintcenter.
[2] Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections. Wireless connectivity available on the HP LaserJet Pro 400 color MFP M475dw only.
[3] HP Smart Install works with Windows only.
[4] Requires a wireless access point and an Internet connection to the printer. Services may require registration. Availability varies by country, language, and agreements, and requires a firmware upgrade. For details, www.hp.com/go/eprintcenter.
[5] May require a firmware upgrade.
[6] Mobile device must be wireless-enabled. Printer must be HP ePrint-enabled. Feature may require driver or apps, available for download at www.hp.com/go/eprintcenter. Wireless direct printing available only on the HP LaserJet Pro 400 color MFP M475dw.
[7] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[8] Compared with HP LaserJet Pro M1536. Assuming customer is printing at least 30% of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[9] HP LaserJet 305X Black Toner Cartridge not included; please purchase separately.
[10] Energy savings based on internal HP testing of Auto-Off setting compared with default setting. Minimum savings based on a 45-minute sleep delay. Maximum savings based on a 1-minute sleep delay. Actual results may vary.
[11] Compared with products that use traditional fusing.
[12] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle
  • Print, copy, scan and fax with one efficient, networked HP LaserJet MFP
    Achieve bold text and smooth color with HP ImageREt 3600 and Original HP LaserJet toner cartridges.Produce color marketing materials in-house on a range of media sizes and use tips and templates from HP.Print black text affordably-at the same cost per page as a black-and-white HP LaserJet printer.
  • Networked multifunction capability
    Boost productivity and save time with print speeds up to 20 ppm A4 and 21 ppm letter.Convert hard copies to digital files quickly and easily – scan to a USB drive, email or network folder.Easily manage paper use with automatic two-sided printing.
  • Make an impression with professional colour marketing materials created in-house
    Achieve crisp, detailed text and consistently smooth colour with HP ImageREt 3600 and Original HP LaserJet toner cartridges.Print black text affordably – at the same cost per page as a black-and-white HP LaserJet MFP.Save money with high-capacity black print cartridges designed for frequent printing.
  • Conserve resources with innovative energy-saving features
    Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't. Save even more energy with Instant-on Technology.Manage paper usage and get up to 50% paper savings, using automatic two-sided printing.Get centralised, easy access to custom, energy-saving options and printer settings with HP EcoSMART Console.Take advantage of free, easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
HP LaserJet Pro MFP M475dw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Recommended Monthly Volume
1000 - 2500 pages
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 dpi
Display
3.5"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AC 230 V
42 cm x 48.3 cm x 50 cm
29.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
1000 - 2500 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
Standard Memory
192 MB 192 MB
Max Supported Memory
448 MB 448 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Image Enhancement Technology
HP ImageREt 3600
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Scanning
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Distinctive Ring Pattern Detection (DRPD), automatic redialing
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
300 sheets
Max Media Capacity
550 sheets
150 sheets
ADF - 50 sheets , Input tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, Apple Mac OS X 10.5, MS Windows 7, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5
Software Included
Drivers & Utilities
AC 230 V
465 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
6 Watt
EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1, GB 9254 Class B
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year
42 cm
48.3 cm
50 cm
29.5 kg
Shipping Width
60.6 cm
Shipping Depth
60 cm
Shipping Height
50 cm
Shipping Weight
35 kg
Sound Emission
51 dBA (operating)
15 °C
30 °C
10 - 80%
