Get fast, high-performance printing with advanced security features. Expand as your business needs change, using an open EIO slot, open memory slot, two internal accessory ports for connecting HP and partner solutions and optional paper trays.
Count on HP for performance and durability
Help prevent unauthorized network admission with 802.1X, which provides device authentication prior to admission.All-in-one Original HP print cartridges with built-in intelligence deliver reliable, consistently outstanding results, page after page, cartridge after cartridge. Get more out of each cartridge with the optional high capacity toner cartridge.Save time and reduce costs and your environmental impact. Print high-quality, two-sided documents and use up to 50 percent less paper using automatic, two-sided printing. This device uses up to 13 percent less energy per page than previous models.Twenty-five years of continuous innovation and reliable, professional-quality printing – HP LaserJet remains the brand businesses count on. -
Get peace of mind with advanced security features
Help secure business-critical data using IPSec and other advanced security features.Easily retrieve stored confidential print jobs. Retrieve a list of stored jobs using the "menu" button and enter your PIN using the 10-number key pad on the printer's control panel.Add a secure hard disk to the printer's open EIO slot. The optional HP High-Performance Secure EIO Hard Disk provides advanced security features to protect sensitive data at rest on HP printers and MFPs – without impacting device performance. -
Gain the flexibility to expand with your business
Improve your productivity. Get the capacity to do more with a 1600-sheet maximum input capacity. Add an optional 500-sheet paper tray for better paper handling.Meet your business needs with robust paper handling. Automatically print on different types and sizes of media – up to A6 – with easy-to-load, adjustable paper trays. -
Easy to use and manage
Get convenient, walk-up printing, using the front-panel Hi-Speed host USB 2.0 port. Increase your manageability with a full portfolio of innovative HP Certified Partner solutions that integrate easily into your existing infrastructure.Reduce calls to IT. Users may easily use and maintain the printer with convenient features like the four-line LCD control panel and the "Show-Me-How" menu.Easily setup and manage your print fleet with industry leading, award winning HP Web Jetadmin, and the HP Universal Print Driver. Easily install, configure, monitor, troubleshoot and manage your printing devices from anywhere on the network.Enjoy easy recycling – cartridges returned via HP Planet Partners are recycled responsibly.
- HP LaserJet Enterprise P3015x - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 21.2 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN
- Processor
- 540 MHz
- RAM Installed (Max)
- 128 MB (640 MB) - DDR2 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, cards
- Total Media Capacity
- 1100 sheets
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 2000 SP4, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 44.8 cm x 41.2 cm x 48 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Built-in Devices
- Status LCD, USB Hub
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- PostScript Support
- Standard
- Processor
- 540 MHz
RAM
- 128 MB / 640 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm
- Media Weight
- 60 g/m² - 199 g/m²
- 1100 sheets
- Max Media Capacity
- 1600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 100000 pages
- 1500 - 5000 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x EIO
- Connections
- 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- Power Device
- Power supply - internal
- 780 Watt
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- 44.8 cm
- 41.2 cm
- 48 cm
- 21.2 kg
HP 55A Black Original LaserJet Toner Cartridge | In Stock | £128.09 |
HP 55X High Yield Black Original LaserJet Toner Cartridge | In Stock | £201.02 |
HP 55X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £361.83 |
