Your basket is empty
HP LA1905wg 19" LCD - widescreed, 1440 x 900, DVI-D, VGA
HP Compaq LA1905wg 19-Zoll-Breitbild-LCD-Monitor
Quicklinx: 7CV2WS00 Mfr#: NM360AT#ABU
  • Compatible with Windows 7
Achieve your business goals with the comfort-focused, energy-efficient and kind to the environment HP Compaq LA1905wg 19-inch widescreen LCD monitor.
HP Compaq LA1905wg - LCD monitor - 19"
LCD monitor - 19"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.283 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
44.5 cm x 24.4 cm x 37.1 cm
6.2 kg
English / Europe
Microsoft Certification
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
Plug and Play, CSA, TUV, VCCI, BSMI CNS 13438 Class B, cUL, GS, EN55022 Class B, FCC Part 15 B, CCC, EN55024 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, TCO Displays 5.0, ISO 9241-307, CISPR, GEEA, AS/NZS 3548 Class B
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.283 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Screen Coating
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HDCP
6.2 kg
DVI-D , VGA , DisplayPort , 2 x USB downstream , USB upstream ( Type B )
Mechanical
Tilt Angle
40
Flat Panel Mount Interface
100 x 100 mm
USB cable
English / Europe
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
33 Watt
Power Consumption Stand by / Sleep
2 Watt
EPEAT Compliant
EPEAT Gold
5 °C
35 °C
20 - 80%
