HPE 900GB 6G SAS 10k rpm SFF (2.5 Inch) Enterprise 3 Year Wty
Quicklinx: 7QNTWS00 Mfr#: 619291-B21
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
  • Performance and Reliability for Multiple Application Environments
    HPE Server SAS Hard Drives deliver high reliability for mission-critical applications.Robust SAS interface (dual port, full duplex) for increased performance.HPE Smart Carrier for HPE ProLiant Servers (both Gen8 and Gen9 are supported). They maintain backward compatibility with existing standard hot-plug carriers to provide support for HPE ProLiant G7 and earlier servers and server storage enclosures.They are ideal for transaction processing, database applications, analytics, high-performance computing and business applications.The 512e Advance Format Drive is ideal for 4KiB aligned operating systems and applications. They also support legacy 512K native applications.
HPE Dual Port Enterprise - hard drive - 900 GB - SAS 6Gb/s
Hard drive - hot-swap
900 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
10000 rpm
7 cm x 10 cm x 1.5 cm
3-year warranty
HPE D2700, P2000 G3, SB40c; Integrity BL860c i2, BL860c i4, BL870c i2, BL890c i2; Modular Smart Array 1040, P2000 G3; ProLiant BL460c G7, BL465c G7, BL620C G7, BL680c G7, BL685c G7, DL120 G7, DL160 G6, DL165 G7, DL180 G6, DL320 G6, DL360 G7, DL370 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G7, DL980 G7, ML110 G7, ML350 G6, ML370 G6, SL390s G7, WS460c G6; StorageWorks D2200sb, SB40c; StorageWorks Disk Enclosure D2700; StorageWorks Modular Smart Array P2000 2.5-in, P2000 G3; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3800sb G2; StorageWorks Network Storage System X1600 G2, X1800 G2
900 GB
2.5" SFF
SAS 6Gb/s
Bytes per Sector
512
7 cm
10 cm
1.5 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
3.57 ms (average) / 7.3 ms (max)
Track-to-Track Seek Time
0.21 ms
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
10 °C
35 °C
HPE D2700, P2000 G3, SB40c storage blade , HPE Integrity BL860c i2 (2.5"), BL860c i2 Base (2.5"), BL860c i4 (2.5"), BL870c i2 (2.5"), BL890c i2 (2.5"), BL890c i2 Base (2.5") , HPE Modular Smart Array 1040 Dual Controller SFF Storage, P2000 G3 FC MSA Dual Controller Virtualization SAN Starter Kit, P2000 G3 SAS Dual Controller SFF Array , HPE ProLiant BL460c G7 (2.5"), BL465c G7 (2.5"), BL620C G7 (2.5"), BL680c G7 (2.5"), BL685c G7 (2.5"), DL120 G7 (2.5"), DL165 G7 Performance (2.5"), DL360 G7 Central Management Server (2.5"), DL360 G7 Efficiency (2.5"), DL360 G7 Special Server (2.5"), DL370 G6 High Performance (2.5"), DL370 G6 Special Server (2.5"), DL380 G7 Efficiency (2.5"), DL380 G7 Special Server (2.5"), DL385 G7 HE (2.5"), DL580 G7 (2.5"), DL580 G7 Base (2.5"), DL580 G7 High Performance (2.5"), DL585 G7 (2.5"), DL585 G7 Base (2.5"), DL585 G7 Performance (2.5"), DL980 G7 (2.5"), ML110 G7 Base (2.5"), ML110 G7 Entry (2.5"), ML370 G6 Special Server (2.5"), SL390s G7 (2.5"), SL390s G7 1U Left Half Width tray (2.5"), SL390s G7 1U Left Tray Node Server (2.5"), SL390s G7 1U Right Half Width tray (2.5"), SL390s G7 1U Right Tray Node Server (2.5"), SL390s G7 4U Left Half Width tray (2.5"), SL390s G7 4U Right Half Width tray (2.5"), SL390s G7 Base 1U left Half Width tray (2.5"), SL390s G7 Base 1U Right Half Width tray (2.5"), SL390s G7 Entry 1U Left Half Width tray (2.5"), SL390s G7 Entry 1U Right Half Width tray (2.5"), SL390s G7 Performance 1U left Half Width tray (2.5"), SL390s G7 Performance 1U Right Half Width tray (2.5"), WS460c G6 Graphics Expansion (2.5"), WS460c G6 Workstation (2.5") , HPE StorageWorks D2200sb PCIe Storage Blade , HPE StorageWorks Modular Smart Array P2000 G3 SAS Dual Controller, P2000 G3 SAS Dual Controller SFF Array , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3800sb G2 , HPE StorageWorks Network Storage System X1600 G2 (2.5" SFF), X1800 G2
